Rear sway bar end links . Can't find them anywhere
Discussion in 'Gen 3 Prius Accessories and Modifications' started by EGGS, Jun 30, 2016.
  1. EGGS
    EGGS Member
    108
    NYC
    Installed my trd Rsb in my 2010 and I love it . Only problem is my right end link is developing play and a "clunk" . I can't seem to source just the rear end links anywhere . I found the front . Just can't find the rear without buying the whole kit again .
    Part numbers , links , Corolla end links that work even adjustable whiteline ones and work open to suggestions
    Tanks!
  2. sfv41901
    sfv41901 Masta S
    4,591
    5,292
    Palmdale, Ca
    Is this the Prius Plus Performance RSB?
    iPhone ?
  3. tweedle99
    tweedle99 Member
    99
    57
    Round Rock, TX
  4. sfv41901
    sfv41901 Masta S
    4,591
    5,292
    Palmdale, Ca
  5. mrstop
    mrstop PWR Mode
    742
    329
    109
    Cincinnati, OH
    I have been having a similar clunk in the rear of my car. I originally thought it was the hatch, but in closer inspection it looks like my endlinks are also worn. I'm a little disappointed they only lasted about 40K miles and <4 years.
  6. sfv41901
    sfv41901 Masta S
    4,591
    5,292
    Palmdale, Ca
    Mine lasted just about the same time.....40k
    iPhone ?
  7. mrstop
    mrstop PWR Mode
    742
    329
    109
    Cincinnati, OH
    For those looking for a more economical and perhaps durable option to the factory TRD part PTR11-47012 I found an aftermarket alternative. I took a gamble and based on looks picked up Moog K90341 and K90340 from Advance Auto. They were about $36 with a 30% off discount. This certainly beat the $90-$100 for the TRD. They also appear to be more robust and have a grease fitting.
    While they are for an Acura / Honda they are a direct fit. I assume Toyota picked an off-the shelf part rather than fab a low volume sway bar end link. Pics showing the comparison are attached.
    If you are looking for something with more bling, you may be able to use the following:
    Metaleckz, Lucifer and Dylan Doxey like this.
  8. Joele3
    Joele3 Active Member
    118
    189
    Bay Area
    Good looking out. I'm going to need new ones myself real soon. Keep us updated if any issues arise. Thanks !
    brettlocs likes this.
  9. mrstop
    mrstop PWR Mode
    742
    329
    109
    Cincinnati, OH
    Thanks. The only potential issue is that the grease fittings are snug to the parking brake cable. I'm hoping that there is little to no movement to wear out a hole in the cable.
    I did spend a few minutes to paint them black with some Rustoleum. The parts seem to be unprotected so I didn't want rusty metal showing behind.
  10. Dylan Doxey
    Dylan Doxey Senior Member
    1,389
    3,455
    92
    I like the way the Cusco rear sway bar has no end links at all.
    I like the look of this because:
    • no end links to wear out
    • improved ground clearance.
    I wonder if anyone here has tried them both and knows how the performance compares?
  11. mrstop
    mrstop PWR Mode
    742
    329
    109
    Cincinnati, OH
    I haven't had any clearance issues with the TRD bar. My one concern is that, in researching the endlinks, some Scion owners (which uses the same bar) reported the bar breaking on early versions without the end-links.
    Dylan Doxey likes this.
  12. Kenny94945
    Kenny94945 Active Member
    784
    400
    Sausalito
    2016 Prius v wagon
    Those Moog links look super strong.
    Seems easy enough to add some extra protection for the grease fitting to cable.
    Nice find...thanks.
  13. tweedle99
    tweedle99 Member
    99
    57
    Round Rock, TX
    Can you just cap off the top endlink?
  14. mrstop
    mrstop PWR Mode
    742
    329
    109
    Cincinnati, OH
    Possibly. I need to take a better look at the interference this weekend as it was getting dark when I installed. The Moog parts were a little weird in that they were two different designs in the boot and grease fittings. The passenger side had a straight zerk fiiting whereas the driver side was a right angle. I think swapping out the driver side to a straight fitting might lessen the interference and give a bit smoother surface.
  15. Rickkiboi
    Rickkiboi Junior Member
    17
    16
    Palmdale, CA
    @mrstop Thank you for the heads up! My 2010 Prius 5 was rear ended (on the 30th day of ownership) and deemed a total loss. Although the car seemed to drive just fine, the cost to repair was just under $5K because of body work. When the RSB was pulled, drivers side end link was bent. I've since purchased a 2012 Prius III that I'm starting build up, thanks again! IMG_2643.JPG IMG_2644.JPG
  16. ASRDogman
    ASRDogman Senior Member
    6,093
    3,273
    Seriously? That's $5000 worth of damage? I'm not calling you a liar, it just seem like that's a lot of money
    for something seemingly simple. Did it damage the frame?
  17. Rickkiboi
    17
    16
    Palmdale, CA
    I know right?!! I was surprised, but the shop GEICO referred me to (one of the best in our area) said the rear quarter panel had to be cut out then a new piece welded back in. In addition, replacing bumper, bumper cover, taillight, cracked interior pieces, bent suspension, etc. Again it seemed to drive fine, don't know if the frame was damaged, but gaps were closed between door panels and the hatchback was difficult to open. Sad to let go of this one!
  18. ASRDogman
    6,093
    3,273
    That's a bummer. It's cheaper for THEM to total it.
    Hopefully the one you get to replace it will be even better!
  19. Rickkiboi
    17
    16
    Palmdale, CA
    @ASRDogman Thanks! I'm building up this 2012 Prius 3, should have the majority of it done by the end of next week. BTW I bought the Moog K90341 and K90340 at Walmart.com for about $14 each, free ship to store for pick up. Thanks again @mrstop! IMG_2897.JPG
    ASRDogman likes this.
  20. Mendel Leisk
    38,732
    It's a damn shame to total a car with that amount of damage; that's a love tap.
