Rear Sway Bar: OKAY to Buy at Junk Yard?
Discussion in 'Gen 2 Prius Accessories & Modifications' started by jbusta, Jun 14, 2017.
  1. jbusta
    jbusta Junior Member
    33
    Hi everyone,
    I had a question about installing a rear sway bar. I know everyone goes for the Progress 62.2150 for the rear sway bar and then the junk yard for the front sway bar.
    However, is it okay/fruitful to get a Rear Sway Bar from something like a 2003-2006 Toyota Corolla off ebay? Is their stock bar thicker/more beneficial/worth it over the stock Prius rear sway bar?
    Cheapest I've found the Progress Bar for is around $140, but I've seen some junk yard rear bars available for around $30-$40.
    Thoughts?
  2. gta_
    gta_ Active Member
    189
    133
    Tracy, CA
    The rear bar on the Corollas from posts on other threads are only 20mm, which is the same size as a Prius Touring rear bar, and only 1mm over a base rear bar. You'd be better off waiting for a deal to show up in the classified for a TRD or Progress one. From what I've also read, is the front sway replacement is the biggest bang for your buck, and the stock Corolla one would be what you want.
    jbusta likes this.
  3. jbusta
    33
    Awesome. Thanks for the insightful post. I'm going to wait for a sale on craiglist for about a month. If nothing comes up I'll go ahead with the direct purchase. Appreciate the help buddy
  4. Kevin_Denver
    Kevin_Denver Active Member
    581
    421
    Denver, CO
    There's also the 26mm Megan sway bar on Ebay: MEGAN corolla rear swaybar | eBay
    I believe it's hollow, so it should behave similar to a 24mm solid bar like the Progress/TRD.
    gta_ likes this.
  5. 69shovlhed
    69shovlhed Surly tree hugger
    2,170
    744
    Delaware
    the corolla bar appears to be a forging, but the prius bar looks to be not much better than conduit. so if your not looking for maximum performance and don't want to spend a lot, the corolla bar should make a noticeable difference. might be able to find one really cheap at the local junkyard.
    05PreeUs and gta_ like this.
  6. 05PreeUs
    05PreeUs Senior Member
    1,097
    563
    MSP
    So Corolla F&R from the scrapper yard when updating to Touring struts and springs from non-Touring!
    Thanks!
  7. 69shovlhed
    2,170
    744
    Delaware
    you will love the improvement, but, don't skimp on tires. and I have to say ecopias suck for handling. definitely getting michelin or conti when these wear out.
  8. Mavi
    Mavi Active Member
    484
    282
    San Diego,ca
    2020 Prius Prime
    So is the megan 26mm hollow the same as the progress 24mm solid bar performance wise?
  9. Mavi
    Mavi Active Member
    484
    282
    San Diego,ca
    2020 Prius Prime
    So I did some research and they are saying it's a solid 26mm bar.. so that might mean it'll make it too stiff.
  10. 69shovlhed
    2,170
    744
    Delaware
    nope. but if you don't do the front too, it will oversteer.
  11. Aztechmaster
    Aztechmaster Member
    38
    76
    S.D.
    I just replaced my stock bars front and rear, used a 07 Corolla front bar and a 08 matrix rear bar. Very satisfied handles much better in curves even loaded. Cost me 65 bucks.
    James1964 and SFO like this.
  12. 69shovlhed
    2,170
    744
    Delaware
    can't beat that with a stick. I guess Toyota figured we were all dweebs that would be driving extra slow to maximize MPG...
    Aztechmaster likes this.
  13. James1964
    James1964 Member
    177
    83
    Vashon Island, WA
    You should do your own prius chat. Your posts are bankable.
  14. 07SacPrius
    07SacPrius Junior Member
    Sacramento, CA
    I am new to Prius Chat but am about to do the sway bar swap by Aztech Master above on my 07 Prius:
    "07 Corolla front bar and a 08 matrix rear bar"
    When I called the junkyard they said for the 07 Corolla there was an option between Japanese or US made?
    Does that make a difference for the front sway bar, bracket, or bushings?
    Aztechmaster which one did you use?
  15. 69shovlhed
    2,170
    744
    Delaware
    I don't think it matters, but if you have a choice go with japan because prius is made in japan.
    07SacPrius likes this.
  16. 07SacPrius
    Sacramento, CA
