Rear sway bar question
Discussion in 'Gen 3 Prius Accessories and Modifications' started by crazyjeys, Oct 7, 2012.
  1. crazyjeys
    crazyjeys Member
    135
    16
    Sunny Socal
    Okay, I'm really confused on how the RSB for the Prius works. In my knowledge, the center of the sway bar should bolt to the chassis and the ends should bolt on to both sides of the shock assembly. That's what I've been noticing on cars that have independent rear suspension. Then i noticed one SUV that was in front of me earlier and it had the same setup. Now I don't understand how the RSB works for the prii. I need some clarification please :).
  2. JordanReich
    JordanReich Junior Member
    I bought and installed the sway bar on mine. The beam that goes between the rear wheels is hollow inside, and the rear sway bar tucks up in it, and gets clamped on via some metal bars that come in the package. The ends of the sway bar then bolt into holes on the spring perch, just in front of the eyelet for the lower end of the rear shocks. I thought it was a great upgrade, especially since you're adding a sway bar, not replacing one!
  3. crazyjeys
    crazyjeys Member
    135
    16
    Sunny Socal
    yes, i understand what you're saying but my thoughts were, from what i know (correct me if i am wrong) the sway bar should counteract the force of the chassis with the suspension for it to be effective and minimize the body roll, so if the sway bay is connected to the beam itself and the beam is a one piece structure that is connected to the perches, how does it counteract the body roll? i'm sorry if i'm missing something i just want to understand how it works for the prius before i purchase it :)
    douglasjre likes this.
  4. JordanReich
    I cant go into detail because I dont know it off the top of my head, however the sway bar is not "bolted" to the chassis, rather there are rubber housings that allow for movement. It is basically like adding another crossmember to the rear of the car that has some give.
  5. ken1784
    ken1784 SuperMID designer
    2,940
    1,365
    67
    Yokohama, JAPAN
  6. crazyjeys
    crazyjeys Member
    135
    16
    Sunny Socal
    kmkremer likes this.
  7. toyotechwv
    toyotechwv Toyota Technician
    474
    251
    Princeton, WV
    If you want stock handling then no there is no reason for a RSB. When adding a RSB to a torsion beam it limits the amount of twist in the beam during cornering effectively stiffening the rear suspension. Trust me, they make a difference, but unless you really push your car in corners, it's a waste of money.
  8. DadofHedgehog
    DadofHedgehog Active Member
    681
    281
    northern Virginia
    Here's my 2 cents: the ends of the torsion rear axle are anchored to sprung weight while the ends of the TRD anti-sway bar are anchored to unsprunfg weight (wheels and suspension components below the springs & shocks).
    I've been thinking about your original post while I bolted on the TRD anti-sway bar today and I just returned from flogging the PiP over selected empty parking lots and certain very tight freeway turns (the new SE Freeway - DC 295 merge just past the 11th Street Bridge, for other locals).
    There is indeed a significant difference - the car has ceased to perceivably lean, no matter how tight the turn. I did some PWR-on donuts in an empty parking lot to confirm my butt dyno readings.
    My previous mods are Rude person's's mid-brace and his front brace. I've had those on for months. The anti-sway bar ads another notch of tightness to an already improved car. Yes, I like it.
    One small negative point from my evening flog: a particularly high freeway expansion joint launched the rear end of the car up noticeably further than before, pre-sway bar. This correlates with what I've read about how anti-sway bars transmit the direction of vertical travel from one wheel to the other - and perhaps amplify that effect when both wheels hit a sharp, wide feature like said freeway expansion log-in-the-road, er, "joint".
    This vertical acceleration is what made me deaggregate effects on suspended mass (90+ of the car body and passenger) from unsuspended mass (the wheels and the bottom suspension components). So, I think there is a difference in where the torsion bar axle feeds its forces vice where the TRD bar does.
    Comments?
  9. Former Member 68813
    3,524
    981
    US
    I don't think so.
  10. DadofHedgehog
    681
    281
    northern Virginia
    Jacek, Yeeees? Help me understand the difference in our thoughts so we can both learn. Much appreciate your thoughts in advance.
