Rear tail light LED out/dim 2005
Discussion in 'Gen 2 Prius Main Forum' started by m0fugga, May 27, 2013.
  1. m0fugga
    m0fugga Junior Member
    I apologize in advance if this has been covered already. I searched but couldn't find anything. My passenger side tail light (the upper part above the reverse lights) don't light up when you press on the break. Or rather, they light up, but just not as bright as the driver side. I took the car to the dealership and they told me they'd need to replace the entire tail light and I just wanted to see if that was indeed the case. Please advise.
    Thanks,
    m0_fugga
  2. sfv41901
    sfv41901 Masta S
    4,591
    5,292
    Palmdale, Ca
    That is indeed the case. The LEDs can not be replaced like ur typical incandescent bulb.
    Try searching eBay for a used 1.....just be careful.....they may have the same problem.
  3. m0fugga
    Ok, just wanted to confirm. I'll check eBay and apply all the standard "shopping on eBay rules". I appreciate the quick response.
  4. sfv41901
    sfv41901 Masta S
    4,591
    5,292
    Palmdale, Ca
    Anytime & good luck.
