Rear Tail lignts and running lights out on my 2007
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by PriusinAllen, Aug 8, 2010.
  1. PriusinAllen
    PriusinAllen New Member
    Allen, TX
    Hey there;
    Last nite a driver told me that both my rear tail lights and and running lights were out - but brake lights and license plate light worked ok. I checked the bulbs are they are fine - any suggestions? And any idea where i can find a wiring schematic for the 07?
    Thanks
  2. PriusinAllen
    Allen, TX
  3. TheSpoils
    TheSpoils Member
    304
    49
    New Jersey
    Did you check to see if the lights were in fact out?
  4. Patrick Wong
    18,200
    6,493
    You can find the electrical wiring diagram as well as repair manual info at techinfo.toyota.com
    The 10A TAIL fuse provides power to the front side marker lamps, the rear taillights, and the license plate lights. Since you say that the license plate lights work, that would be evidence that the TAIL fuse is OK.
    What do you mean by "running" lights?
    I suggest that you trace the brown ground wire on both taillights, which go to a common point. That point probably has a loose or broken connection to the body.
  5. WashingtonDoug
    WashingtonDoug New Member
    Washington
    Mine just went out too - thanks for the tip on the brown ground wire, I will start there.
  6. WashingtonDoug
    Washington
    While looking for the wire I pulled both of the sockets out with the bulb still in, said the magic word and put them back into the fitting and they came on, one at a time.
    I see lights out all the time in Prius cars and lost my head lights at 45K. A bit frustrating.
