Rear View Camera Reverse Wire - C1 and C2
Discussion in 'Prius c Audio and Electronics' started by KYBlue, Dec 23, 2013.
  1. KYBlue
    KYBlue Active Member
    227
    111
    For those doing a camera in their C1 and C2, the reverse wire will not be in your radio harness.
    Instead - you can find it in the driver's side, knee area. There is a removable section near the trunk pop latch and to the left of the knee airbags. Remove that panel.
    You'll see a large white connector towards the top, it should mimic the picture I'm showing below.
    You can choose the Brown or Purple wires. These are the wires that feed back to each rear tail light.
    Chris
    firstrival likes this.
  2. gbouten
    gbouten Junior Member
    48
    Alamogordo NM
    I bought a kit for mine that plugged into the back of the radio and it had everything you need. No need to go to all that trouble. I posted the adaptor on this site earlier this year.
  3. KYBlue
    227
    111
    Yes, if you have a 3 or 4 for the kit will work. If you use an aftermarket radio in a C1 or a C2 that harness is not present in the radio since its a "dumb" non LCD/Touch radio from the factory.
  4. kingnba6
    kingnba6 Active Member
    1,013
    241
    NY
    the c1 and 2 dont have the reverse wire in the radio. i thought about running the reverse wire from the kick panel but at the time of my camera install, i didnt have the wiring on hand, so i just ran a wire from the rear reverse light to the front. it wasnt that much of a problem since you are already running the video signal to the front.
    but thanks for the future reference OP
  5. KeepitSimple
    KeepitSimple Member
    127
    Washington, District of Columbia
    what kit? where can one find this?
    I have a prius c 3 and interested in putting in a backup camera.
  6. actiondonkey
    actiondonkey Member
    91
    30
    I just ran it directly to the reverse taillight; much easier and no problems after 2+ years! But It's always great to have additional options.
  7. w2kpugsly
    w2kpugsly Junior Member
    97
    san diego
    How did y'all run the wire from the camera which is outside of the car to the inside. Did you drill another hole or is there an existing one you used. Thx
  8. DickPhillips
    DickPhillips Member
    89
    58
    Mount Vernon, WA
    What do we look for to find this kit and where is it available?
  9. w2kpugsly
    97
    san diego
  10. Aurora
    Aurora Junior Member
    Portland, OR
    2014 Prius c
    By installing an after market device, does it void warranty at all?
    iPad ?
  11. Oatflake
    Oatflake Junior Member
    Glendale, CA
    2014 Prius c
    I have a similar kit from camera-source.com that seems to have the same gear based on the photo, and I'm about to start - which pin are you talking about that is so difficult to remove? Is it on the hatchback, door plastic bits or the frame around the head unit?
  12. kingnba6
    1,013
    241
    NY
    i dont believe it directly voids warranty unless they are able to prove that the device installed is the reason the problem occurred.
  13. w2kpugsly
    97
    san diego
    It's the second pin on the right hand side of the plastic piece that holds the license plate lights and the switch to open the hatch.
    Nokia ICON
Loading...
