Rear View? Do You Get Used to It?
Discussion in 'Gen 3 Prius Main Forum' started by njguy, Mar 16, 2015.
  1. njguy
    njguy New Member
    My wife and I are seriously considering buying a Prius Liftback (not the c and not the v (lowercase v) - the "middle" one). She likes a lot about the car but is concerned about the view out the back window. Because of the way the hatchback is configured, there's a "black bar" about 1/3 of the way up from the bottom, as seen in the rear-view mirror. During the test drive, she found that very distracting. So my question is, do you get used to it? Thanks.
  2. se-riously
    se-riously Active Member
    263
    114
    SF Bay Area
    2014 Prius Plug-in
    Yes, you get used to it, especially with the backup camera. That black bar also cuts off nighttime headlight glare to the rear view mirror.
  3. DoubleDAZ
    DoubleDAZ Senior Member
    1,209
    322
    Peoria AZ (Phoenix)
    I was concerned about that too, but it hasn't been a problem at all. When we travel, I don't even use the lower part because it's covered with luggage and there is the backup camera. Unfortunately, IMHO, the camera takes more getting used to because you have to think about looking at the display when the tendency is to look out the back or the mirror. It's a habit I haven't quite gotten into after almost 9 months and 17,000 miles. We come from a van with it's large rear window and I'm diligent about using my mirrors, etc. The scary thing is how close some drivers pull up behind you at traffic lights, etc., because of the "chopped off" design.
    That said, you may never really like it, but it doesn't impact your ability to keep track of what's behind you or backing up. I even parallel parked once in LA and managed it the first time mostly using the camera. I do wish the camera had a grid like some others I've driven; my brother's Sonata and my daughter's Optima. I do back up mostly using the side mirrors and backup camera once I've determined it's clear behind me.
    And, compared to our old van, the Prius is much darker in night traffic, probably mostly due to the auto-dimming rearview mirror.
  4. maurices
    maurices Member
    128
    37
    Sartell, Minnesota
    Since the only people that ride in the car are my wife and me, I removed the rear seat headrests, what a difference that has made to the rear viewing area. Would recommend this for all of PC!
    PriusIndia and fuzzy1 like this.
  5. DoubleDAZ
    1,209
    322
    Peoria AZ (Phoenix)
    I might try that for our next trip. My wife prefers leaving the rear seats up to stow my camera bag, the food bag, cooler, overnight bag, etc. I guess she finds it easier to get at things when she needs to.
  6. jry423
    jry423 Member
    96
    37
    Ohio
    Yes, definitely get used to it. I used to try to use both rear windows. Now, I ignore that useless little mini window on the bottom, and it's much less distracting.
  7. bisco
    52,521
    nope, hate it. and the rear corner views as well.
    hlunde and Okinawa like this.
  8. Mike500
    Mike500 Senior Member
    2,593
    767
    The obstructed rear view is the very reason that I got my Prius"v" wagon.
  9. Mendel Leisk
    42,040
    Don't think I'll ever get used to it. Best I can do is uneasy truce. When doing lane changes in particular, never 100% sure regarding who might be in the myriad vision obstructions, take it real slow. The rear wiper is pure token too.
    hlunde and CR94 like this.
  10. CR94
    CR94 Senior Member
    2,768
    1,211
    Northwestern S.C.
    I find it easier to adjust to the spoiler across the rear window than to the obstucted view both to the left front and to the right rear. That said, the too-small triangular right rear windows are still a lot better than solid opaque areas would be. I peep through the right one when making a left turn at one of those oddly angled intersections (common in S.C.!) that require you to look for traffic coming from your right rear.
  11. Sampino35
    Sampino35 Junior Member
    23
    NC
    That was a HUGE concern of mine when I test drove my Prius. However, after driving it awhile, I noticed that most of the rear traffic can be seen out of the top window and the "split" doesn't bother me at all now. Maybe its because I'm short and how I have the seat positioned, idk. But there are so many other great things about the Prius, so don't get hung up this one little thing.
  12. magnumrtawd
    magnumrtawd Member
    306
    72
    Toledo,Ohio
    The head rests can be folded down out of view.
  13. qdllc
    qdllc Senior Member
    1,377
    400
    I've gotten used to it, but when that bar blocks what you want to look at, it's a bit annoying. Also, the lower part catches dirt/dust really bad. The upper glass lets stuff run off when it's raining, but the lower spot stays dirty...obstructing vision.
    No rear back up camera. Eventually will install one aftermarket since the system supports it and there is more than one plug-and-play option available aftermarket. I do okay, but too often someone comes by and I just can't judge if they are coming even though round visibility isn't all that bad.
  14. CapeAnn
    CapeAnn Member
    114
    25
    Northeast United States
    I got used to it - but it's not great. I have almost developed a type of intuition regarding drivers in my blind spot. If there is any good news about the lack of vision - it has made me a more conservative driver when I am in the Prius.
  15. Paul Schenck
    Paul Schenck Active Member
    524
    307
    Fresno, California
    I thought the same thing, only thing I didn't like in '05 when I got mine. I sure got used to it, and realized it really works well. They added the camera in later models.
    iPhone ?
  16. Chris S
    Chris S Active Member
    323
    111
    Gilbert, AZ
    I didn't care for the lower window and hatchback feeling that cars were on my bumper so I'd adjust the rear view so the bar in the middle was at the bottom of the rear view. I could still see cars fine. I also used the small blind spot mirrors on both mirrors and never had a problem with the rear corners
    #16 Chris S, Mar 17, 2015
  17. Paul Schenck
    524
    307
    Fresno, California
    First generation Prius owners complained about visibility and eleven windows was the result makes you feel like a grasshopper or a fly with an eye on every side of your head. I learned to love it notice the dark tint on the lower window? It blocks the headlights on that car that just pulled up behind at the stop light! When you leave it parked outside? Notice how the other windows are all covers with condensation and not that one? Sure makes getting out of a tight parking space easier doesn't it? Remember don't just use those side mirrors as rear view mirrors. They can save lives if you adjust them out to cover the lane next to you they'll reduce the blind spot caused by your optic nerve and give you 360 view with only 45 turn of the head! That's impressive engineering.
    iPhone ?
  18. Mendel Leisk
    42,040
    ^ I think there's something detrimental to having your view broken up into multiple smaller windows, vs one contiguous view. Just harder to process.
    Another thought: we've got the OEM rear-view camera, it's extreme wide-angle, really hard to judge distance.
  19. Okinawa
    Okinawa Senior Member
    1,333
    320
    I had a Prius Two for 3 years and I did not get used to it. I did not have a back-up camera. That would certainly make a difference.
  20. kutztown46
    kutztown46 Junior Member
    31
    Kutztown, PA
    2022 Prius
    We have done this also and it helps a lot. I wish the spoiler was not there. It annoys me but I suppose we will get used to it.
