Rear View Mirror Project
Discussion in 'Gen 3 Prius Technical Discussion' started by Judgeless, Aug 23, 2009.
  1. Judgeless
    Judgeless Senior Member
    1,821
    257
    Cleveland, OH
    I am thinking of moving the sensor in the rear view mirror to the top of the mirror. You can watch the line of light from the car behind you. The fin on the back of the car blocks the sensor all the time. The line of light always hits the top of the mirror.
    I wonder how hard it would be to drill a hole in the top and move the sensor.
  2. rachaelseven
    rachaelseven New Member
    616
    212
    Adams, MA
    Wouldn't it be easier to just turn the mirror over, as was suggested in another thread recently?
  3. SlowTurd
    SlowTurd I LIKE PRIUS'S
    1,156
    333
    nj
    i had similar problems in a 2001 subaru ll beaner wagon.
    the rear seat middle headrest put the photocell in shadow.
    i just removed the headrest and it was good to go 90% of the time.
    i'll be happier to manually switch it.
  4. Judgeless
    1,821
    257
    Cleveland, OH
    I read about flipping the mirror over a while ago. I was able to flip it over with out a problem. When it was flipped over I could not get it in a position to see out the back window. I tried every option.
    Since I posted this I have found that you can adjust the rear view mirror up and down. I have it pushed all the way up to the black clamp. This seems to help.
  5. DavidA
    2,342
    1,818
    Chicago western burbs
    In another thread a poster suggested to artificially darken the photocell on the front of the mirror with some filtered plastic. The purpose was to raise the ratio of brightness to darkness so the mirror darkens at lower rear light levels than the default design. But yes, that spoiler is what's really the problem.
  6. Seymour1
    Seymour1 Member
    249
    29
    I did did realize that it could be adjusted up and down. Thank you Judgeless. I moved it up and it helps. I will road test it soon. A longer arm between the mirror and the mount would allow more up and down adjustment.
