rear view screen Genll 2006
Discussion in 'Gen 2 Prius Main Forum' started by brin wood, Mar 11, 2014.
  1. brin wood
    brin wood Member
    100
    upstate NY
    Mine is quite dark and like, foggy? Is this typical or is it a problem ?
  2. JC91006
    16,482
    8,400
    Clean the lens
    SM-N900P ?
  3. tanglefoot
    tanglefoot Whee!
    625
    188
    Colorado
    Have you cleaned the camera lens in a while? It's located under the license plate lip, left of center, in a black housing. Wet-clean it to prevent scratching the lens.
    Ha--you beat me, JC.
  4. brin wood
    brin wood Member
    100
    upstate NY
    Went through the carwash today.........thought that would help; it didn't.
  5. JC91006
    16,482
    8,400
    It's not as clear as looking through your phone camera. It's quite foggy compared to your phone resolution
    SM-N900P ?
  6. tanglefoot
    tanglefoot Whee!
    625
    188
    Colorado
    The car wash might not get it. I'd get out there with a spray bottle/hose and a sponge/rag/paper towel. Inspect the lens afterwards...maybe it's badly scratched/hazed.
  7. Patrick Wong
    18,200
    6,474
    Certainly possible that the rear camera is failing, if it doesn't help to clean the lens.
  8. JC91006
    16,482
    8,400
    how long have you noticed the backup camera being foggy? did this just happen or you always felt it was foggy from day 1?
  9. brin wood
    brin wood Member
    100
    upstate NY
    I bought the car in Oct.2013; it has been hazy since then. I thought it was just me but appears hazy no matter the light or weather.
  10. JC91006
    16,482
    8,400
    You should compare it with another prius. Your expectations might be a bit high for this camera, it's very basic, not high resolution at all
    SM-N900P ?
  11. Britprius
    Britprius Senior Member
    5,194
    1,916
    Herefordshire England
    If the image is dark there are settings on the MFD to alter the brightness and contrast, "while you are in reverse".
    John (Britprius)
  12. brin wood
    brin wood Member
    100
    upstate NY
    Thanks for the tip John, will try that.
  13. non_nahs
    non_nahs Junior Member
    Baden, Pennsylvania
    Did you try going back and cleaning it with a rag or towel? That seems to help mine even when the car wash doesn't.
