Rear wheel camber adjustment on prime keeps getting off
Discussion in 'Prime Technical Discussion' started by mczouav, Sep 6, 2018.
  1. mczouav
    mczouav Member
    BE
    On the 10k and 15k garage visits, the rear wheel camber test failed. Off by ca. 2 degrees. Every time, the garage asks for 100$. I d like to know which bolt needs to be adjusted. Since i have the tools, i might as well try to get it fixed myself before going to the garage next time (if it was the toe that get off, i would not even try). It already looks off again by the same angle as before. Any idea where to find the info is welcome. I believe a new bolt might be needed too. It is a double wishbone suspension. Cheerios, max
    49,489
    is this at an authorized toyota repair facility?
  3. burnout8488
    burnout8488 Member
    124
    81
    Endwell, NY
    Two degrees would be noticeable. Are they pulling your leg, or can you actually tell from looking at both rear wheels? -2º should be some pretty obvious inward tilt if the other wheel is closer to 0º.
    There's no reason it wouldn't hold unless they aren't tightening the camber bolt properly, or you're hitting some nasty bumps with the same wheel.
    Also, I don't think alignment check is part of the ToyotaCare checks, are they doing this as a courtesy? (Or a money grab?)
  4. mczouav
    mczouav Member
    BE
    It s at a toyota dealer. They systematically check it. The tolerance is 2 degrees, but it s kind of visible and with a right angle tool on the ground, its noticeable. This is not part of the toyota care. Paying 100$ every time i go to the garage is not my cup of tea when it should not happen... I can see a bolt under the car but i am not 100% sure its for camber. It is holding the bottom suspension arm. ( We live in memphis area, the roads are not that bad. )
  5. bisco
    49,489
    what do they say when you ask them?
  6. Lucifer
    Lucifer Senior Member
    1,014
    485
    Nh
  7. padroo
    padroo Senior Member
    2,763
    2,250
    #7 padroo, Sep 6, 2018
  8. mczouav
    mczouav Member
    BE
  9. mczouav
    mczouav Member
    BE
    That it needs adjusting or tires will last longer and car is less stable at high speed.
  10. mczouav
    mczouav Member
    BE
    Tires will last less ' of course ;)
  11. bisco
    49,489
    i'm no expert, but i think you're being played. you can either adjust the suspension or you can't.
    if nothing is broken, it shouldn't go out of adjustment in 5,000 miles, unless you're off roading.
  12. Lucifer
    1,014
    485
    Nh
  13. Mendel Leisk
    38,726
    Memphis, Tennessee in the USA? What's "BE"? Not Belgium? It helps to know location man. :confused:
    Do you know the camber spec. You say it's out by 2 degrees, but from what baseline. The spec probably is a bit of camber, ie: the wheels should splay out slightly at the bottom, for more stability when cornering.
    Also, per @bisco: if it was off, and they adjusted it, why would it go off again??
    Maybe get a short Toyota Tech Info subscription and search it up (as my grandson says :)).
    Is that third gen, what book? Fourth gen may be adjustable, having independent rear suspension.
    #13 Mendel Leisk, Sep 7, 2018
  14. mczouav
    mczouav Member
    BE
    Yes that is a strange situation. The garage check can t be failed 2x on the same wheel without an underlying problem. Cheerios.
  15. mczouav
    mczouav Member
    BE
    Thanks, let s say i travel a lot between continents. But the prius primes are all the same regardless of location, made in japan...so far.
    The wheel alignment tool might be a good investment if this misalignment keeps happening... I was going to do it with a large right angle tool ruler. Can t go too wrong if i do it before going to the garage and they check it anyways with their fancy alignment devices.
  16. Mendel Leisk
    38,726
    Yeah a carpenter's square would do the trick. Do you know the camber spec?
    I believe this is rear camber spec for third gen. The Repair Manual is poorly written, doesn't specifically say rear, but a few pages back talks about the (adjustable) front camber adjustment, so just connecting the dots:
    mczouav likes this.
  17. Mendel Leisk
    38,726
    You can do a little trigonometry if you have the spec'd camber angle: set one leg of the angle on the slab, push it in till it touches the rubber at six o'clock, measure the corresponding gap to the rubber at 12 o'clock, measure the distance between those two contact points, and those two measurements are legs of right angle triangle, the shorter leg divided by the longer leg is the "tan" of the angle.
    Following that, I'm getting 0.5"/19.5" (right side) and 0.25"/19.5" (left side), which equate roughly to (degree) angles of 1.3 and (right) and 0.7 left. Left side is not pulling it's load, but meh: the tires are wearing fine, so I leave it be. Third gen is not easily adjustable, requires heroics with shims, too much hassle.
    (Rim protector edge on our 17" make for crisp measure.)
    #17 Mendel Leisk, Sep 7, 2018
    mczouav likes this.
  18. padroo
    2,763
    2,250
    If Toyota can't please you I would take it to a frame and axle shop and see what they say. They are used to seeing all kind of oddball alignment problems and are probably have better equipment than a Toyota dealer. You would have to pay for it out of your own pocket.
  19. Vman455
    Vman455 Senior Member
    534
    551
    The Middle
    As someone else pointed out, the Gen 4 uses a different rear suspension design. Through Gen 3, when the Prius used a torsion beam, adjustments were made with shims. The Prime, like the current Prius, uses upper and lower control arms, with a trailing arm and locating link, all bolted to a knuckle, for an independent rear suspension setup. I haven't looked at one in person, only the diagram, but if one of the bolts on the lower link is eccentric it could be used for toe adjustment; my last car, a 2005 Civic, used a design like this.
    However, I don't know of any cars outside of some exotics that have adjustable camber, especially in the rear. It's fixed by the lengths of the arms by design, although adjustable length control arms are available for popular models (like my aforementioned Civic). If the OP's camber is off by that much in just 5,000 miles, there's something wrong.
    mczouav likes this.
  20. Mendel Leisk
    38,726
    This is not something you'd do on a whim though. Aren't those shims installed behind everything, even the bearing, which is a royal bear to remove, once it's rusted in there for a few years. If the tires look fine and you're not noticing anything, say when cornering, I would just leave it be.
    mczouav likes this.
