rear wheel hub assembly brand recommendations?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by jdh81478, Feb 16, 2015.
  1. jdh81478
    jdh81478 Junior Member
    Fremont
    Can anyone recommend a particular brand of rear wheel hub assembly? My right, passenger side rear wheel is starting to make a noises. Sounds like the ball bears are getting loose and need to be replaced.
    Thanks
  2. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    I used OEM Toyota. I believe there are aftermarket brands.
    I replaced my rears last fall and they needed it for sure but now I believe my fronts are going too. Same sound that was coming from the rears. :(
  3. bestmapman
    bestmapman 04, 07 ,08, 09, 10, 16, 21 Prime
    1,289
    242
    Kentucky near Cincinnati, OH
    I got mine (rear) from advanced auto parts. They have the OEM. It was about $250 ish.
  4. telmo744
    telmo744 HSD fanatic
    2,178
    768
    Portugal
    I find no particular reason to replace an accessible bearing prematurely...IMPOV
  5. texasboy77904
    texasboy77904 Junior Member
    92
    Im only 57k miles on my 2011. I just had the front drivers side done free (covered under drivetrain warranty) but the rear is not covered past 3/36k miles.
    Ive got double confirmation that one of the rears is on the way out also.
    I would also recommend moogs from advanced auto parts.
    #5 texasboy77904, Feb 17, 2015
  6. ZBrink
    ZBrink Member
    81
    33
    Fairfax, VA
    I just replaced my drivers side front wheel hub/bearing assembly. I ordered the part from Rock Auto. I have used them for years as they offer quality brands of all levels to suit your needs and budget and around re generally less expensive than the local stores . The brand I purchased was SKF as it had a 36 month/45k mile warranty included for $204.79. It is definitely a quality item and solid alternative to buying the part from Toyota. They had a Timken branded assembly for around $156 I believe as well.
    shawn.ne likes this.
