Rear Wheel Noise
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Dan05979, May 18, 2016.
  1. Dan05979
    Dan05979 Member
    181
    101
    New York City/Upstate NY
    I'm not sure if this was brought up before or ever but I just replaced the rear tires because of flat spots, and I thought it was causing the louse truck like noise. After I replaced with new tires I'm still hearing this loud noise on the highway. I currently have 84K on a 2010. Any ideas?
  2. Jimi1976
    Jimi1976 Active Member
    242
    124
    Denver, CO
    Hub
    Dan05979 likes this.
  3. Dan05979
    Dan05979 Member
    181
    101
    Something common I guess. Just googled it
  4. Jimi1976
    242
    124
    Denver, CO
    One way to find out, is to (carefully) turn while rolling, and see if the noise goes away.
    For example: if rear driver hub is suspect, turning car a sharp left will temporarily take pressure off left side of the vehicle, and hub noise may go away.
  5. Dan05979
    Dan05979 Member
    181
    101
    I'll check that, thanks.
  6. Dan05979
    Dan05979 Member
    181
    101
    Went to the dealer, I forgot when I bought the car certified used I had an extended warranty with a $50 deductible. So they will replace the left rear wheel hub when the parts come in next wednesday. Thank god!
    Jimi1976 likes this.
