Rear Window Wiper has 2 settings that are the same?
Discussion in 'Gen 3 Prius Main Forum' started by nemrut, Oct 13, 2009.
  1. nemrut
    nemrut New Member
    57
    san francisco
    anyone else notice that the farthest top setting and farthest bottom setting for the rear window wiper are the same? what do you think the reasoning is behind this?
  2. Tideland Prius
    16,445
    You're referring to the rear washer fluid. The reasoning is that you're one click away from spraying the window rather than having to turn all the way to one side of the knob to spray washer fluid to the rear.
  3. 32kcolors
    32kcolors Senior Member
    5,683
    953
    124
    Redondo Beach, CA
    I've never tested it, but on the Lexus RX350 "3" (the farthest top setting) is "Washer operation" and "4" (farthest bottom setting) is "Washer/wiper dual operation."
  4. exbauer
    exbauer Active Member
    1,188
    102
    Washington
    when you turn wiper stalk counter clockwise and hold it there you get the rear wiper on and washer fluid. when you turn it one time clockwise you get intermittent rear wiper. turn it again clockwise you get constant rear wiper. turn it again clockwise and hold it you will get rear wiper on and washer fluid.
