Rear-wiper: Anybody miss it yet on the new Prime?
Discussion in 'Prime Main Forum (2017-2022)' started by PokemonPrius, Dec 24, 2016.
Tags:
  1. PokemonPrius
    PokemonPrius Junior Member
    Salt Lake City
    2013 Prius Plug-in
    Just wanted feedback from people in snowy/rainy areas--do you feel you really miss the rear window wiper?
  2. Will_Prius16
    Will_Prius16 Member
    127
    64
    Now in West Covina, CA
    Did not realize there isn't one for the prime. I find it very useful on the 2016 prius hatchback
  3. priuscatprimeguy
    priuscatprimeguy Senior Member
    2,730
    2,640
    Farmington Hills, Michigan
    I still find myself trying to turn on the rear wiper, (lol, force of habit):D:p:LOL::ROFLMAO:
  4. Optimus PRIME
    Optimus PRIME Active Member
    180
    141
    SF Bay Area
    definitely miss that feature a LOT. Anyone know why the Prius back window was designed with a curve?
    Rosanne Shalf likes this.
  5. john1701a
    john1701a Prius Guru
    12,753
    5,245
    57
    That curve funnels air, providing a little blowing help for window clearing. The dip also increases visibility... no more snow pile up area like the wiper would leave on the previous generations.
  6. ForestBeekeeper
    ForestBeekeeper Active Member
    700
    274
    Maine
    At home we park inside a carport. A week ago I parked for an hour on the street and our Prime got covered in loose snow, I jumped in it and the windshield wipers easily brushed away the snow on the windshield. I turned on the rear defrost and I returned home.
    The next morning in the carport, I noticed that the rear window gully was still filled with snow. So I started my trip with the rear defrost going. That snow stayed in place. ... Three days later I finally brushed it off manually.
    In my experience, the read defroster seems to loosen the grip of ice. But it is not enough to cause the ice/snow to leave. Nor is there enough air turbulence at normal interstate speed [82mph] for the snow to leave on it's own.
    ssamd and priuscatprimeguy like this.
  7. bisco
    49,371
    was watching a show on car manufacturing the other day. they were building a peugeot with curved rear glass, and claiming it was the only one in the world.
    interestingly, some nodders here remove the rear wiper from their pri.
  8. Mendel Leisk
    38,644
    I rarely use the rear wiper on our 3rd gen; it doesn't sweep much area, when I do use it. I suppose to clear snow it's most needed.
  9. bisco
    49,371
    same. depends on the weather. i probably use it a half dozen times a winter. but i don't have a regular commute that might take me out in the snow more often.
  10. priuscatprimeguy
    2,730
    2,640
    you need to get out more often bisco:cool:
  11. bisco
    49,371
    oh! i thought i was getting out too much. it's scary out there.:cool:
  12. priuscatprimeguy
    2,730
    2,640
    yup agreed. especially after January 20th:eek:
    jaymac, MNdriver and sonomac like this.
  13. lroki
    lroki Member
    83
    103
    Sacramento, CA
    I have been using RainEx on my glass for awhile. I thought that is Miss the rear wiper, but the RainEx makes it shed water rapidly. Don't know about how it would handle the frozen water versions though. I think that it may help with the release from the glass.
  14. Lee Jay
    Lee Jay Senior Member
    5,850
    4,023
    Westminster, Colorado
    This is likely going to end up my top annoyance with this car. In my other car that lacks a rear wiper, I carry a hand squeegee to clear the rear window at stopping points. I don't care much about rain because I can see right through it, it's snow, ice and slush that's the problem.
    ForestBeekeeper likes this.
  15. lroki
    lroki Member
    83
    103
    Sacramento, CA
  16. Civic4982
    Civic4982 Member
    46
    40
    do not know why they did that :(
    iPhone ?
  17. john1701a
    12,753
    5,245
    57
    Like the regular Prius, air flow over the rear window only happens at slow speeds. So, clearing needed to happen then.
    On the highway, there will be a air cushion. If rain ever starts while you're out in the highway, you'll observe the rear stays dry under the layer of air.
    #17 john1701a, Dec 25, 2016
  18. Tideland Prius
    16,125
    It was for design - the designer really wanted that feature. Aerodynamics was also a smaller part. The designer and chief engineer wanted an even more exaggerated double wave but I guess cost and trying to keep the rear window free of distortion made them settle on this final design.
    Depends on the snow. If it's wet snow, it just piles up and then blocks your view. If it's fluffy snow, it'll pile up and when it gets high enough, it blows away.
  19. bisco
    49,371
    the silver lining is that you won't see any prius rage behind you.:cool:
  20. priuscatprimeguy
    2,730
    2,640
    yeah, maybe, but they're still in your side view blind spots:eek:
