Rearranging sources
Discussion in 'Prime Audio, Electronics, and Infotainment' started by Sddunn, Aug 7, 2018.
  1. Sddunn
    Sddunn New Member
    Nanaimo
    2018 Prius Prime
    So I find when I have my satellite radio on when I first get into the car and I decide to use the steering wheel controls to change the station my radio jumps to am stations. I then have to go into my source selection and choose satellite radio again. I thought this would be because AM is the first source selection when you go to sources. I then reorganized the selections so satellite was my first selection. Well to my disappointment this did not fix the problem and when I went back into the source selection AM was put back to the number 1 position. Long story short, has anyone else had this problem and have you been able to rearrange you source selection and have it stay ?
  2. DavidA
    2,328
    1,812
    Chicago western burbs
    My Prime very occasionally will jump to a different source on its own. It has only happened at startup, and it is always from Sat to FM or from FM to AM. I haven't figured out why this can happen other than it is one level down in that menu, as it is set up as the default. I haven't reorganized it like you have..
    Sddunn likes this.
  3. Sddunn
    Sddunn New Member
    Nanaimo
    2018 Prius Prime
    Yep,that is what mine does and only at start up. Well glad to know I’m not the only one.
    Thanks for your input :)
  4. Old Bear
    Old Bear Senior Member
    712
    1,049
    Boston, Massachusetts USA
    I don't know if this will solve your problem, but take a look at this PriusChat post by from Elektroingenieur from last January.
    I had an intermittent problem with my Prime's radio/usb player controls locking up and there being no way to do anything except adjust the volume. Could not even turn off the radio -- just silence it by using the volume control. Pulling over and turning the car off and back on fixed the problem and it then might not occur again for a month or more.
    At my request, my Toyota dealer just installed the patch which Elektrogenieur suggested, but I have not had enough time to know for sure that it fixed the problem. Hopefully it did.
