Reasons NOT to buy the Prius C?
Discussion in 'Prius c Main Forum' started by Nel, May 20, 2013.
  1. Nel
    Nel Member
    174
    84
    SF Bay Area
    I am a former owner of the Prius liftback. That was a lease, and I no longer have it. Needless to say, I long for a car with such great mileage! I am currently considering a Prius C Three (gotta have the Smartkey and maybe even a moon/sunroof).
    I also want to look at both sides of the picture before making the purchase. I know most of the great things about the C already, but I want to know some reasons NOT to buy the C (if any). I want to know the most trivial things you can think of as an everyday driver/owner. For example, my old 2010 Prius liftback's armrest/storage was ALWAYS open to access the secondary cupholder, thus the back seat had hampered leg room. Let me know anything a new owner should know!
    Thanks guys, and I'm looking to possibly make the purchase within the next week :)
  2. JimboPalmer
    12,470
    6,870
    Greenwood MS USA
    Back seats are not really for adults. No camera. No CARB warranty in CARB states. Less insulation.
  3. Species5618w
    Species5618w Member
    140
    50
    It's a Yaris, nothing more. To me, a Yaris is enough. However, many people buy Camry over Yaris since it suits them better.
  4. css28
    css28 Senior Member
    1,566
    442
    Suburban Detroit
    If you do a lot high speed driving or mountain passes its mileage will probably be worse than for a hatchback.
  5. Hyper_PriusC
    Hyper_PriusC Member
    83
    55
    San Jose, CA
    ^^ totally agreed. Long distance driving isn't very gas saving especially with lots of up hills. i can only rack up 50+ mpg if i can cruise with the EV mode for the majority of the time while driving in the city
    The great milage is more likely to happen if you are strict with pulse and glide or often drive very light pedaled.
    if you can withstand the slowness of the car, I think everything else is great. love the hatch back and tiny turn radius.
    DU3L NRG likes this.
  6. DU3L NRG
    DU3L NRG Junior Member
    37
    Too small, no sunroof option available. Less mpg on highway than standard prius. Less power than standard prius. Hope this helps!!
  7. ftl
    ftl Explicator
    1,812
    790
    Long Island NY
    Sunroof is an option on the Prius c Three and Four.
  8. maddog61
    maddog61 Junior Member
    44
    I travel between Revelstoke and Golden, BC...thru Rogers Pass...... 182 miles round trip and right now I am averaging 4L/100Km or 58miles/us gal or 70miles/imp.gal
    twalatimer likes this.
  9. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
  10. Sean McConky
    Sean McConky New Member
    Buffalo, NY
    I take issue with CR over their slamming the C for being slow. I owned a 2008 Honda Fit and it was 0.1 seconds faster in 0-60 time, yet they loved the Fit for how much fun it was to drive.
    If you need it to move, it will move. Obviously, you aren't getting a Corvette.
    cknfts, PriusC-illa and nordiska like this.
  11. cwerdna
    12,544
    2,123
    SF Bay Area, CA
    FWIW, in looking at CR's test results, in the 09 Fits they tested, they got 0-60 mph in 9.2 sec w/the manual and 10.7 sec w/the auto vs. the 11.3 sec they achieved w/the Prius c.
    I also recall the Fit doing well in terms of top speed in some publication's slalom test.
  12. JMD
    JMD 2012 Prius 4 Solar Roof
    3,779
    1,282
    Not a lot of car to protect you in a severe accident
  13. Sean McConky
    Buffalo, NY
    The '09 was an updated engine from the '07-'08. However, CR loved the Fit right from the start, including the '07-'08.
    SPH-D710 ? 2
  14. novasquid
    novasquid Junior Member
    49
    Northern VA
    - the front cup holders are too small for my coffee mug
    - armrest storage space is tiny
    - acceleration is painfully slow
    - highway mileage sucks
  15. cycledrum
    cycledrum PSOCSOASP
    8,245
    1,202
    NorCal
    99 total HP and I'll bet it's an tire noise echo chamber on the freeway.
  16. cwerdna
    12,544
    2,123
    SF Bay Area, CA
    Yep. Also, OP might want to see the posts I linked to at Can't decide between a C or a regular Prius | PriusChat re: crashes of involving a much heavier vehicle vs. a lighter one.
    Curb weight of a Prius c is 2500 lbs per Toyota Prius c - 2013 Models: Prius c One, Prius c Two, Prius c Three, Prius c Four. Liftback is a 3042 lbs (Toyota Prius Hybrid - 2013 Models: Prius Two, Prius Three, Prius Four, Prius Five). In the links I mentioned, I listed some other typical curb weights and results of IIHS crashing unequal weight vehicles into each other.
  17. cwerdna
    12,544
    2,123
    SF Bay Area, CA
  18. cwerdna
    12,544
    2,123
    SF Bay Area, CA
    Hmm, when I select used Fit on CR, I get the same 09 5MT again but then also see an 07 5MT. They got 9.9 seconds in the 0-60 mph on the latter.
  19. Nel
    Nel Member
    174
    84
    SF Bay Area
    Any annoying nuances to mention? The comment above about the cupholder being too small for our generally obese sized drinks is a good mention. I'll be bringing my primary water bottle and rearview mirror to the test drive.
    Any bicyclists here? I used to be able to fit my 58cm road bike in my Prius lift w/o disassembling ANYTHING from the bike. Can I still fit a decent sized bike into the C if I remove the front wheel?
    I didn't see any hidden storage spaces in the C like I was used to having in the Prius lift under the trunk bed. Is there hidden storage spaces to be aware of?
    Is there an AC outlet anywhere?
  20. cwerdna
    12,544
    2,123
    SF Bay Area, CA
    Rear visibility thru the rear window is very poor in the Prius c due to the large rear head restraints. I noticed this when I took a test drive awhile ago. If you have one and have nobody riding in the back, I'd remove them and store them somewhere in the car, in the event you take on passengers.
    OTOH, don't know how it compares to the currently shipping liftbacks.
