Rebuilt pack - P3000 and P3004 codes, block voltages going negative?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by dubseven, Oct 31, 2018.
  1. dubseven
    dubseven Junior Member
    Denver, CO
    Just rebuilt a pack, all the cells had 5k + mAh capacity. Polished all the bus bars, new hardware.
    Getting P3000 and P3004 codes. If I look at the block voltages, 2-3 of them flip negative for a second or two, then back to positive, and continue to do so intermittently. Any ideas on where I should start looking?
  2. TMR-JWAP
    TMR-JWAP Senior Member
    6,230
    5,931
    Columbia, SC
    The wire sensor harness is either damaged at those tabs or the plug has corrosion. It's not uncommon for small cracks to form where the wire is crimped to the tab. Removing the busbars to clean/polish them greatly increases the odds of damaging the tabs. It's also not uncommon for corrosion to be present on the plug that attaches to the ecu, or on the actual plug socket pins on the ecu.
    Raytheeagle and SFO like this.
  3. dubseven
    Denver, CO
    Makes sense. I swapped a few ECUs, and no dice. I'll pull the pack and check the harness.
  4. ericbecky
    ericbecky Hybrid Battery Hero
    4,371
    3,222
    Madison, Wisconsin
    Or you did not properly tighten the nuts using an inch-lb torque wrench, so something is over/under tightened.
    But, as mentioned above, check the voltage sensing wires at the crimp connector. Often is is quite corroded. If need be you can replace the wire frame itself for ~$80.
    Raytheeagle likes this.
