Reccomend a shop/person to do engine replacement in SF Bay Area
Discussion in 'Gen 2 Prius Main Forum' started by Feekman, Nov 15, 2021.
  1. Feekman
    Feekman Junior Member
    East Bay, Ca
    Hi everyone,
    My shop recommended that I get an engine replacement after cylinder 1 failed on my 253k Prius gen 2
    Looking at the second-hand car prices ideally, I want to keep my Pri.
    Shopping around for a full engine replacement service, so far found a place in Sacramento, (Denko) They do a swap for 1200$ (rebuilt 140k miles not great) however. Dealership quotes for 7-10k which is not worth it.
    I live in East Bay and hoping to find something closer to me, and leads are welcome
    49,694
    luscious garage
    Travis Decker likes this.
  3. SFO
    SFO Senior Member
    5,297
    4,237
    Northern California
    Could you please tell us more about the cylider 1 failure? (rings wore out, throw a rod, sucked a valve, etc)
    Were there any OBD2 codes reported?
    You may be hard pressed to find a better deal if that includes the used engine and installation.
    Which area of the east bay are you near?
    FYI : you're moderated until you've posted 5 times.
    Raytheeagle likes this.
  4. Another
    Another Senior Member
    1,802
    511
    Naples, Florida
    A couple of questions come to mind. What’s the warranty on the $1200 deal? Maybe the guy knows all you need is a ring job and wants your old engine?
  5. koco
    koco Member
    113
    38
    Las Vegas
    Engine World in Emeryville looks to have used motors for $750 probably a JDM import with low mileage. They can send it to a local shop for install.
    Feekman likes this.
  6. Travis Decker
    Travis Decker Active Member
    139
    115
    Portland OR
    arts in berkely or luscious garge. I would prefer a good used engine over a “rebuilt”
    Who builds better engines Toyota or Larry’s engine rebuilding?
  7. koco
    koco Member
    113
    38
    Las Vegas
    Yeah, a seasoned used motor is less likely to fall apart right away.
  8. richard203
    richard203 Member
    205
    45
    SF
    i just yelped that shop and its 1star o.0
    SFO likes this.
  9. Feekman
    East Bay, Ca
    Maybe however my engine has 253k on it, so getting a 140k engine doesn't sound like that bad of a deal.
    They reported low compression on Cylinder 1 and said further investigation will just cost more money and labor here is +160$/hr
    So I like the idea of putting a newer engine in. But open for recommendations
    If I end up putting a replacement engine do I have to worry about the next Smog test?
    Someone else suggested them too ( another shop) Thanks for your recommendation.
    #9 Feekman, Nov 18, 2021
  10. koco
    koco Member
    113
    38
    Las Vegas
    Engine World does appear to have 2 bad reviews recently. I was lucky enough to get a good Honda motor that ran like new from there and I sent someone in for an MR2 motor that was also good. These were almost 10 years ago and things can change. They import motors from Japan mostly. I was able to go in and hand pick my motor from 5 of them.
  11. SFO
    SFO Senior Member
    5,297
    4,237
    Northern California
    That would depend on the quality of the replacement engine, and the existing emissions system on the vehicle.
    The smog tech won't know or care about the replacement engine, but will likely look for an OEM catalytic.
