Recent cross country trip
Discussion in 'Tesla' started by bwilson4web, Jul 2, 2022.
  1. bwilson4web
    15,513
    My 2019 Tesla Model 3 Standard Range has +72,290 miles with ~7.9% battery degradation. I recently completed a solo drive with AutoPilot between Coffeyville KS and Huntsville AL:
    • 794 miles
    • $59.64 Supercharger fees
    • ~48 mph.
    So $59.64 would buy ~11 gallons of regular or ~10 gallons of diesel. The car would have to get 72.19 MPG on gas or 79.4 MPG on diesel. Around town, the car gets ~3x more miles per kWh or ~216 MPG.
  2. dbstoo
    dbstoo Senior Member
    1,323
    700
    Near Silicon Valley
    2024 Prius Prime
    XSE Premium
    How much energy did you use. The unit of measure should be kWh, since that is easily convertible to all systems. Trying to use dollars to convert types of energy does not work well unless you include all prices and all quantities of everything at every step of the conversion.
    Too bad there is no transparency at the supercharger to let you know how much energy it pulled from the grid for every kWh that it pumped into your car.
  3. bwilson4web
    15,513
    Here is my source:
    The cost comes from a Tesla page not shown.
  4. Trollbait
    11,513
    Most people will care just about what it costs them.
    bwilson4web likes this.
  5. bwilson4web
    15,513
    I agree but if I am asked for engineering units, I try to comply.
  6. dbstoo
    1,323
    700
    Near Silicon Valley
    2024 Prius Prime
    XSE Premium
    While that may be true, the "cost" is totally useless to anyone who does not drive the same car in the same area. For instance, I can relate that last week I drove 479 miles through northern California and it cost me $45.67 So how much good does that do you?
    But if I told you that I did 38.7 miles on level freeways using 194 watts per mile on battery, well that's directly related to what you can expect no matter where you are or what you drive. If I then told you that I drove the rest of the way (440.5 miles) through multiple mountain passes at 80 mph with a head wind for an average of 50.63 miles per gallon, then that's another one that you can compare to your usage with other cars.
    Those numbers, by the way, are exactly what my car reported for the trip last week. Yep. Not even the names have been changed to protect the innocent.
    There have been trips that over or underperformed. Best gas usage was 71 MPG on a level freeway doing 65 MPH. Most frequent mileage on 500 mile trips (central cal to either southern California or Oregon) has been 61 MPG. Not too bad for a car that only cost $24,000.**
    Dan
    ** If memory serves correctly.
  7. bwilson4web
    15,513
    That was my 2019 Model 3 Standard Range Plus cost with trade-in of our 2017 Prius Prime. But it also taught me clues to improve future cross country trips. For example, Corinth MS has a free L2 charger that in an hour can add 25-30 miles along the route. In contrast, using the Tupelo MS Supercharger added more than 30 miles diverting off the direct route. I could have taken a cat-nap at Corinth without adding to the trip duration. Lesson's learned.
  8. Trollbait
    11,513
    It gives me an idea of how much it costs per mile compared to my car. Most people just know how it costs to fill their tank, and how often they fill it. They really only care about actual energy efficiency as far as it affects how much they pay. The OP did give specific start and end points with an average speed.
    I'm not likely to be driving down to Bob's region, and if I go to California I'll be renting a car. So even knowing specific energy consumptions isn't going to give me much more info for comparing to my current car. It's fun to share the info, but of interesting trivia when compared to my data needs.
    When I want compare the efficiencies of different models, I'll use EPA ratings. I know how my current and past cars did compared to their ratings, so I can infer what I'll get in another car.
  9. dbstoo
    1,323
    700
    Near Silicon Valley
    2024 Prius Prime
    XSE Premium
    If you know specific energy consumption, you can do comparisons that make sense. The cost of a tank of gas or the cost to charge at a supercharger is useless information; The supercharger cost varies a LOT from location to location and day to day, the same as the cost of gasoline.
    But the amount of energy used per mile stays fairly constant under similar conditions.
    I don't use the EPA ratings for much. They don't tell me what is possible with conservative driving. They only tell me what a certain car rated on a certain simulated course. The car is as likely as not to be tuned to do well on the test.
  10. dbstoo
    1,323
    700
    Near Silicon Valley
    2024 Prius Prime
    XSE Premium
    Bob, Your screen shot of the Tesla dashboard shows a lifetime average of 227 Wh used per mile. Your trip meter says that you used 221 Wh per mile on the trip, purportedly while driving at 48 MPH. That's a little worse than your average.
    Are you claiming that you only use 73.8 Wh per mile in town? Really? If that were true, it should be making headlines across the country. What I see from your screen shot was 2 miles in 6 minutes using 209 Wh. That's what? 20 MPH?
    I think you need to take some remedial math classes. None of your math ever adds up.
  11. Trollbait
    11,513
    The EPA testing controls variables which allows like to like comparisons of different models. If you know what your energy efficiency is in your current car is on a route, they also used to estimate what you can get in another model. If you are getting, say 10% more than EPA in your car, you will very likely get 10% more with another car.
    Tuning concerns are the opposite. There are rules in place to keep manufacturers from optimizing the cars too much for the test. Worn tires have lower rolling resistance for example. So the amount of wear is limited to about 4000 miles.
    If you do something for fuel economy that takes the car out of factory spec, like having higher tire pressures, then that shows up in your ratio to the EPA rating.
  12. bisco
    49,397
    i'm more concerned with charging time and number of stops
  13. dbstoo
    1,323
    700
    Near Silicon Valley
    2024 Prius Prime
    XSE Premium
    Aye, and there's the rub. The "too much" is evidently poorly defined and poorly enforced. VW is not the only one who has had cars that performed better on tests than they did in real life. They just got caught doing it.
  14. 3PriusMike
    2,963
    2,314
    Silicon Valley
    But they cheated primarily on the emissions not the MPG efficiency, right?
    Mike
  15. dbstoo
    1,323
    700
    Near Silicon Valley
    2024 Prius Prime
    XSE Premium
    My memory fails me on the details:
    From Car and driver: In the test mode, the cars are fully compliant with all federal emissions levels. But when driving normally, the computer switches to a separate mode—significantly changing the fuel pressure, injection timing, exhaust-gas recirculation, and, in models with AdBlue, the amount of urea fluid sprayed into the exhaust. While this mode likely delivers higher mileage and power, it also permits heavier nitrogen-oxide emissions (NOx)—a smog-forming pollutant linked to lung cancer—up to 40 times higher than the federal limit. That doesn’t mean every TDI is pumping 40 times as much NOx as it should. Some cars may emit just a few times over the limit, depending on driving style and load.
  16. John321
    John321 Senior Member
    1,199
    1,198
    Kentucky
  17. bisco
    49,397
    ouch, there was a lot of anti tesla bias hidden in thar article.
    'is it worth it' is a strange question to ask or try to answer for someone else. prius owners have been asked that for years.
    #17 bisco, Jul 4, 2022
    Trollbait likes this.
  18. John321
    1,199
    1,198
    Kentucky
    I missed the anti tesla part it just seemed to me they talked cost. My impression was they took the total cost-purchase price, insurance etc.
    I am ambivalent about Tesla and my impression was that here are the facts, you need to do the figuring for your individual situation, but I have no strong felling either way for Tesla and that may lead me to not pick up on some things in the article.
    Only posted it as thought it was neither for nor against Tesla just fact based.
    If it was biased, I apologize as that wasn't my intent.
  19. dbstoo
    1,323
    700
    Near Silicon Valley
    2024 Prius Prime
    XSE Premium
    When the article is labeled "what does it cost to charge a Tesla", it should have max and minimum prices for charging within the target area for the article's readers. If it's targeted to American readers, it should have the high and low throughout the USA.
    It should not have wording like "$0.26 is a common price that we see, so we will use that" for the calculations.
  20. bisco
    49,397
    agreed. it should actually be an explanation of how to understand your electric bill
