Recent right front passenger whirring sound sporadic
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Marjohn, Jul 31, 2017.
  1. Marjohn
    Marjohn New Member
    Ohio
    I'm trying to trouble-shoot so I can discuss with the mechanic. Also need to know if I should go to the Toyota garage or the general repair we've used for other repairs. Our 2008 Prius has a little more than 73000 miles on it, mostly town driving. Recently, I heard a whirring sound between 35-45 mph. The noise is almost melodic. The first time I heard it, I thought it was coming from my grandson's toy gun, but they are all out of the car now and I still heard the noise. I heard it first about 2 weeks ago, then nothing for a week. and then more frequently last week. It seems to happen on turns or turning. I'm thinking brakes, or power steering, maybe bearings or a tire out of round (I have run over a curb recently). I haven't had brakes put on the car and I've heard that chirping noise indicating they should be changed. I thought it might be the power steering pump, but from this forum, I learned there isn't one on a Prius .Safety is a concern, since I take the grandkids around. I appreciate any advice. Thank you.
  2. Travis Decker
    Travis Decker Active Member
    139
    115
    Portland OR
    You probably need a new wheel bearing. Any decent mechanic should be able to figure it out you don't really need a hybrid specialist
  3. fotomoto
    fotomoto Senior Member
    5,602
    3,781
    So. Texas
    The most common reason for a noise from the front end during a turn is the CV (constant velocity) joint/shaft.
    49,715
    good mechanic will figure it out. have them inspect the pad thickness. i don't know what the chirping noise is, but 78,000 miles is pretty early for brakes.
