Recently bought a 2016 Prius V 'package 5', want to show off my baby + ask a few questions
Discussion in 'Prius v Main Forum' started by wowbobwow, Sep 19, 2018.
  1. wowbobwow
    wowbobwow Junior Member
    34
    Bay Area, California
    2016 Prius v wagon
    So after my wife was rear-ended and needed a car (her trusty old Scion xB was totaled), I gave her my 2008 Prius Touring Edition and upgraded myself to a 2016 Prius V 'package 5'. I just had the windows tinted (don't @ me, LOL) - here are a couple pics:
    Anyway, now that I'm done showing off, here are a few questions in no particular order:
    1. I love this car already, but I'm kinda surprised how loud the road-noise is, esp. at freeway speeds. Are there any tips or tricks I might employ to reduce it?
    2. The "Premium JBL Sound System" is shockingly lackluster - it's tinny and sounds thin and almost 'hollow' even when the Bass slider is set to max - a significant downgrade from the JBL sound system in my 2008 Prius (the one my wife now has). Are there any recommended upgrades or enhancements I might look into?
    3. Is there a way to completely reset the "Favorites" on the stereo? The previous owner has a TON of presets (both for AM/FM and for the SiriusXM radio), and since they lived in a totally different area and had very different tastes from me, it's becoming tedious to slowly replace their favs one at a time
    4. Speaking of SiriusXM, I find that the signal seems to cut out a lot while driving around town, probably due to trees and/or buildings. Is there any better antenna for this, or is it just a fact of life with satellite radio?
    5. Other than new floor-mats, are there any suggested upgrades / enhancements I should look into?
    Thanks for any feedback guys!
    Raytheeagle, m.wynn and bisco like this.
  2. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,429
    2,394
    Taylors, SC
    Check out the Prius v modification forum as well as the Priuschat Shop.
    51,758
    gorgeous.
    only way to reduce road noise is quieter tyres (you can try playing with air pressure) and sound deadening material added to doors, spare tire well, bulkhead, wheel wells and floors.
    all the best with your new baby!(y)
  4. rjparker
    rjparker Tu Humilde Sirviente
    10,013
    6,195
    Texas Hill Country
    Michelin tires help but concrete roads still set up harmonics. Some have used sound deadener mats in the back but they can get messy in high heat parking conditions.
    Most improve the speakers and some add line level amps for the rear door speakers.
    Many have replaced the xm preamp built into the antenna base. Toyota now has a test rig for the problem. Bigger cities employ land based transponders to handle buildings and parking lots. You can also stream your xm subscription free with their app.
    Some have installed an oil catch can on the engine. You might invest in a mini vci Techstream obd2 to keep an eye on the hybrid and other specialized ecms.
  5. Sooner Al
    Sooner Al Active Member
    385
    340
    Oklahoma, USA
    2016 Prius v wagon
    I bought WeatherTech laser measured floor mats for our 2016 Prius v Three...
    I highly recommend them...
    wowbobwow likes this.
  6. wowbobwow
    34
    2016 Prius v wagon
    Just ordered some - thank you!
  7. Georgina Rudkus
    3,429
    2,394
    Taylors, SC
    My husband's older friend made and installed a behind the grille mesh rock guard in the lower grille of my car to lessen the possibility or a rock strike that would likely destroy the expensive AC condenser. I was surprised how big the openings in the lower grille were and how unprotected this area is. 2012-14 center installed.jpg 2012-14 installed on car.jpg
    TheTewks likes this.
  8. Georgina Rudkus
    3,429
    2,394
    Taylors, SC
    This is the same lower behind the grille screen on my husband's friend's 2015 Prius v. 2015-17 installed on car.jpg
    TheTewks and icyrius like this.
  9. Raytheeagle
    Raytheeagle Senior Member
    11,265
    15,520
    2019 Prius Prime
  10. Kenny94945
    Kenny94945 Active Member
    845
    421
    Sausalito
    2016 Prius v wagon
    We enjoy our '16 V level 3
    1) That grille guard seems like an excellent mod...form & function.
    2) Roadnoise.
    That's a big ticket.
    Tires may actually be the simplest.
    But we have a roomy, echoing interior.
    Really need to stripe all the carpeting and headliner and dyno mat.
    But, if a hobby, I would start by removing the plastic fender liners and dyno matting
    them.
    You could also remove the door panels and dyno the outer door panel, which
    will improve your stereo tone.
    3) Stereo
    Others better than I can advise.
    4) FWIW
    If a hobby, I could see putting in thicker sways bars and chassis braces.
    The V has a bounce and sway system that is difficult to find info on....do a search
    here, I think I posted about it a year ago.
    At least for me I feel side winds while highway cruising.
    Again I really think these are good super practical cars.
    Scribe and Georgina Rudkus like this.
  11. Georgina Rudkus
    3,429
    2,394
    Taylors, SC
    IMG_7641.JPG Just changing the color of the vertical switch panel around the start-stop, park and buttons and shifter completely transforms the look of the control center area. The shorten shifter shaft and custom black shift knob further enhances the look.
  12. CLUBGUY
    CLUBGUY Member
    293
    49
    Cincinnati
    Lower doors and handles bright strips
  13. PreusV
    PreusV Junior Member
    16
    Chicago
    2013 Prius v wagon
    I ordered these for my 2013. The driver mat fits poorly and doesn't match the floor pegs.
    Love the white, glass roof, and grey wheels!
  14. Tideland Prius
    16,536
    Just do a factory reset on the head unit. It'll wipe out all the previous owner's settings and then you can start from scratch :)
    It should be under Setup --> General?
  15. Sooner Al
    385
    340
    Oklahoma, USA
    2016 Prius v wagon
    Interesting...ours fit perfectly...
  16. bat4255
    bat4255 2017 Prius v #2 and 2008 Gen II #2
    668
    267
    Dodge Co. Wisconsin
    2017 Prius v wagon
    Road noise is an issue for me as well, but it is definitely quieter than the '13 Outback I had. I also did notice something while doing 4 road trips last year and this year (30,000 miles total).
    1- Either I'm getting used to it, or the tire are becoming quieter. I have read where the tires can get quieter as they wear. I have also read where they can get nosier. I depends on the tire brand I guess.
    2- Adjusting the tire pressure by even a few pounds can make a noticeable difference in ride, handling and quiet. I currently run at 38 PSI for a good compromise for me.
    3- I currently have 39,000 on the OEM tires. When it comes time to replace, I am going to try Goodyear Comfort Treads. My '08 did get quieter over the OEM's
    4- The road surface makes a big difference. Some concrete expressways are just horrible while others are much quieter.
    5- Wind noise can be an issue, as the glass and body seems to be thinner. Rain almost sounds like hail hitting the car.
    Overall I am really enjoying or '16
  17. mikefocke
    3,972
    1,796
    Sanford, NC
    Fit my 2012 v perfectly of course I removed the factory floor mat to allow the WT mat to seat on the peg. Left that factory mats under the WT mats in the passenger, back and trunk spaces.
  18. farmecologist
    farmecologist Senior Member
    1,958
    1,799
    Southern MN
    BTW - I have switched to Husky brand liners. They have 'spikes' on the back that 'grip' the floor. Works great on the passenger side and rear seat area. When I had Weathertech, they would slide around a bit..especially on the passenger side. And I find the quality to be just as good...if not better than WT.
  19. PreusV
    16
    Chicago
    2013 Prius v wagon
    I purchased mine on Amazon assuming they would fit perfectly. I stupidly waited for late fall to put them in which went past the return window. I contacted Weather Tech about the mats and they agreed they fit improperly. Because the Amazon seller wasn't an "authorized seller" Weather Tech couldn't help me other than offering me a 10% discount on rebuying the mats directly from them. Lesson learned - test the product within the return window.
  20. mikefocke
    3,972
    1,796
    Sanford, NC
    What about the Weathertech mats fits wrong? I ask because mine fit just fine and have for 7 years.
