Recirc/Fresh Air Setting
Discussion in 'Prius v Technical Discussion' started by Barb Cranston, Jul 17, 2012.
  1. Barb Cranston
    Barb Cranston Junior Member
    Mass
    At Toyota dealership for 10g service. I mentioned that my air conditioning system, not matter when/how activated, will always default to recirculation mode e.g. new engine start/choose A/C - always defaults to Recirculated air, and remains there until I change it to fresh air.
    Service writer said: duh
    Is this normal?
    Thanks for any information you can provide
    B
  2. Barb Cranston
    Mass
    [should qualify: it is normal for the service writer to say duh; is the A/C function normal
  3. parnami
    parnami Member
    227
    47
    .Lancaster, PA (Amish Country) :)
    When it's hot, and my car's set to "normal" mode, it starts out in recirculate, gradually reduces fan speed, then switches to fresh air. However, when set to "eco", it remains in recirculate mode. My guess is that is where you have your car set. Try switching to "norma"l and see it it behaves differently.
  4. rjparker
    rjparker Tu Humilde Sirviente
    7,918
    4,680
    Texas Hill Country
    Agree with parnami
  5. Lats118
    Lats118 Junior Member
    CT
    The manual says recirc mode "will help reduce the burden on the air conditioner and reduce fuel consumption". Perhaps this is why it stays on in ECO mode?
  6. Adam H
    Adam H Junior Member
    61
    Mine (v3) too defaults to recirc, and I don't like it, because often the inside temp is higher than outside when starting, and also I want fresh air to come in.
