recirculation air setting in cabin
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by whodat, Mar 4, 2008.
  1. whodat
    whodat Member
    117
    Aptos, CA
    There is a recirculation air setting for the interior (its the sideways U with the arrow) in the climate control panel.
    I normally drive with the air setting in recirculation mode to avoid inhaling exhaust from cars in front.
    I've noticed that recently the recirculation setting changes (without me changing it) to non-recirculation of air (i.e. getting air from the exterior).
    Is this suppose to happen or does the closed vent flap open because of vibration or external air pressure?
    Thanks
    Dave
  2. richard schumacher
    7,663
    1,038
    United States
    On my 2004, if the defrost is on when I turn the car off, the air source setting changes itself to external when I turn the car on again. Very annoying. Perhaps it does this in other circumstances also.
  3. hyo silver
    hyo silver Awaaaaay
    15,232
    1,563
    off into the sunset
    I hunch the air conditioning (cooling, heating, defrosting...) system is just trying to be efficient. If the air outside is cooler, it will choose to bring some of that inside, rather than cooling the air that's already there. I much prefer mostly outside air, as it keeps me more alert on long trips.
  4. Doc Willie
    1,717
    142
    Out there, somewhere
    The A/C system tries to regulate humidity as well as temperature. It will bring outside air in to keep the humidity from building up, and to prevent the windows from frosting inside.
  5. hyo silver
    hyo silver Awaaaaay
    15,232
    1,563
    off into the sunset
    'Tries' being the operative word. Around here, the humidity is sometimes so high we need personal flotation devices to leave the house. Any idea if there's an external humidity sensor?
