recirculation and thermostat
Discussion in 'Gen 2 Prius Main Forum' started by Mehmet alb, Jul 18, 2022.
  1. Mehmet alb
    Mehmet alb Junior Member
    77
    Turkey
    for the 2007 prius, the RPM and thermostat are changed every few thousand kilometers. In general, for example, what should be changed at 100 thousand kilometers
    #1 Mehmet alb, Jul 18, 2022
    49,534
    translation please?
    Mehmet alb likes this.
  3. Tombukt2
    Tombukt2 Senior Member
    9,237
    1,619
    Durham NC
    You should be able to look up a list in your native language in your country for the Prius or it's counterpart in Europe is begins with an A I can't remember the name. And then you will see the recommended change intervals for many of the things on the car. If everything is working well change the oil check the transmission oil and pretty much leave it alone of course keep good tires brake shoes and pads for stopping and there are apps you can get online to manage your high voltage battery at this stage of the game if it's original is 20 years old so get ready. Good luck
    49,534
    what do you mean by rpm?
    thermostat is not changed unless broken.
    regular maintenance is mostly oil and filter, tire rotations, inspections of parts, systems and fluid levels.
    at 100,000 km or probably higher than that, you get into spark plugs and fluid replacements.
  5. SFO
    SFO Senior Member
    5,297
    4,237
    Northern California
