Recommend a 12v battery charger
Discussion in 'Gen 2 Prius Main Forum' started by Berch1943, Apr 19, 2021.
  1. Berch1943
    Berch1943 Member
    146
    Arizona
    Can anyone recommend the battery charger to use for the 12v battery? Mine shows it has 45Ah. So I looked at the NOCO Genius1 on Amazon , says it charges up to 30Ah if I'm not wrong. The Genius2 would barely do it at 40Ah. Does it matter which one I use?
    49,397
    get the cheapest one, prius battery is small and easy to charge. i charge mine with a 20 year old interstate in my avatar
  3. Berch1943
    Berch1943 Member
    146
    Arizona
    But what does it mean that it "charges up to 30Ah" ?
  4. Mendel Leisk
    38,653
    I think you are wrong. Maybe it’s rated 3 amps, period? That’s a charging RATE basically, and would be fine. Provide a link?
  5. Berch1943
    Berch1943 Member
    146
    Arizona
    Thats what it says directly on their Amazon page. And their rated amps is 1.
  6. bisco
    49,397
    that one looks fine, i can't find the 30 ah thing.
    edit, i see it at the bottom. they are probably talking about how long it takes to recharge. i think you can charge a prius battery up to 4 amps. it's not necessary, but would be faster.
    slow charging is better, unless you're in a hurry.
    #6 bisco, Apr 19, 2021
  7. PriusCamper
    PriusCamper Senior Member
    11,065
    4,504
    Pacific Northwest, USA
  8. jzchen
    jzchen Newbie!
    3,298
    1,009
    Arcadia, CA
    Sometimes batteries are rated in Ah. So maximum recommended size battery would be 30Ah. Since the Prius AGM is 45 Ah they'd have a charger for that. Just remember 4A is as high as you want to go. I've tried 6A and it was too fast.
    moto g(7) power ?
  9. jzchen
    jzchen Newbie!
    3,298
    1,009
    Arcadia, CA
  10. PriusCamper
    11,065
    4,504
    55amp-hour is my standard and price is in $100 range... And if you know your Prius you know 12v car batteries are based on cold cranking amps but not Prius because they don't start the engine, just the computers and the relays. If you want to only spend $113 instead of $300 and have a 12v that lasts near a decade with no issue, let me know and I'll post the link.
  11. alftoy
    alftoy Senior Member
    1,132
    509
    Saskatchewan, Canada
    Get the Schumacher half price $48, Noco over priced.
    • RELIABLE POWER: Delivers 15 Amp charge and 3 Amp to maintain car, truck, SUV, RV, and marine batteries; compatible with standard AGM, and deep-cycle batteries
    • SMART CHARGING: Microprocessor-controlled automatic amperage rate adjustment and multi-stage charging for added precision, safety, and battery life
    jzchen likes this.
  12. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,788
    2017 Prius c
    Good recommendation.
    My Schumacher chargers have performed flawlessly.
    But there are others equally as good.
    Any Battery Tender brand with a capacity of 2 amps or more would be good for battery maintenance when not in use.
    I prefer a 4 amp capacity because it will recover a usable charge quicker if you make a mistake and let it get too low.
    The dual charging ranges of the above model is a plus.
  13. Mendel Leisk
    38,653
    I’m using a CTEK 4.3, hooked up way more than not. Using its quick connect, wired in at the under-hood fuse box. It has got pricey of late though.
  14. alftoy
    1,132
    509
    Also my goto, CTEK 7200 bought it 10 years ago $70cdn. Current price $198? Not sure I would buy it at that price, even tho it has served me well.
  15. Mendel Leisk
    38,653
    Yeah the price blow-up is puzzling. Partially COVID gouging? That’s maybe cynical. NOCO seems the up and comer.
  16. ski.dive
    ski.dive Active Member
    893
    230
    Hutchinson Island,FL. Mt. Snow,VT
    Lots of battery chargers on AMAZON
  17. Berch1943
    Berch1943 Member
    146
    Arizona
    What do you think of this charger? It's at 4amps and the Ah range is 4-100.
    #17 Berch1943, Apr 20, 2021
  18. jzchen
    jzchen Newbie!
    3,298
    1,009
    Arcadia, CA
    Looks decent from what I can tell. It didn't look like it had quick disconnect for ring attachment but not a deal breaker unless you're looking for that?
    moto g(7) power ?
  19. PriusCamper
    11,065
    4,504
    Not enough amps... You want at least double if you're going to charge a drained down 12v car battery relatively quickly...
  20. Berch1943
    Berch1943 Member
    146
    Arizona
    Time is probably not important for me. I'm just looking for one that works best for the Prius 45Ah batteries. Looking to spend no more than $30 Do you have any recommendations?
