Recommendations for Summer Tires?
Discussion in 'Gen 2 Prius Fuel Economy' started by dwgsp, Apr 9, 2017.
Tags:
  1. dwgsp
    dwgsp Junior Member
    Rochester, NY
    I need new summer tires for my 2007 Touring which I got about three years ago. My current tires are Toyo Versado Eco M+S, and I have been consistently getting in the mid-40s MPG.
    I'm not looking for all-season tires, because I switch to snow tires in the winter. Any suggestions?
    Thanks!
  2. Kevin_Denver
    Kevin_Denver Active Member
    581
    422
    Denver, CO
    It depends of course on your priorities. To maximize fuel economy Michelin Energy Saver A/S are the best, but are a bit more expensive than other tires. Bridgestone ep422 is also popular as it's usually significantly cheaper than the Michelins, but will provide fuel economy only a couple percent lower. If handling and noise are important, than take a look at the tires on Tirerack in the right size, as they thoroughly test handling and braking characteristics.
  3. Stevewoods
    Stevewoods Senior Member
    647
    986
    Seattle, WA
    People don't use, for the most part, "summer tires," anymore.
    Get a decent set of all-seasons and call it good. Lots of threads on here about tires. Have a go at it.
