Recommendations on Gen 2 Hybrid Pack
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by PriusNoob86, Feb 23, 2025.
  1. PriusNoob86
    PriusNoob86 Junior Member
    16
    Austin, TX
    I've recently acquired the Red Triangle of Doom/Death/Destruction/etc. on my 2007 Prius (about 184,000 mi). Running an OBD scan returned P0A80 and P3000 codes, indicating failing cell(s) in the hybrid pack. Engine has been strong!
    The vehicle is not my primary driver as of late. I was likely getting ready to sell it after DIY replacing the CV axle and thinking it'd be ready to sell. It's been a great vehicle but I'm not driving it as often as it would prefer! My dilemma is overspending on a battery pack to get it back on the road and sale-ready. Definitely not interested in an OEM pack, but don't want a bottom of the barrel choice either. Would like to pass on something that I feel good about.
    Can anyone recommend remanufactured alternatives (preferably with some form of warranty) that are maybe in the $1,000 (+/- $200) range? Either based on experience or word of mouth?
    Thanks!
  2. Brian1954
    Brian1954 Senior Member
    1,697
    662
    South Central PA, USA
    Look at purchasing a HV battery from a local scrap yard or a place like LKQ and replacing the battery yourself.
    51,009
    try green bean
  4. bennettlyle
    bennettlyle New Member
    United states
    Don't be in a hurry to replace the entire battery pack. Use Techstream to read the specific location of the failed single cell. It's very likely that there is only a problem with 1 or 2 modules. If you have strong hands-on skills, you can go to a local junkyard to remove the battery from a CT200h or Prius of the same generation (the modules are universal). Replacing a single module usually costs very little. Remember to bring a multimeter to measure the voltage and choose the ones with a voltage of over 3.8V to remove.
  5. PriusNoob86
    16
    Austin, TX
    Thanks for the advice. I had considered it - had people saying that replacing modules is a crapshoot and often ends up in failure shortly thereafter. But I think I'm willing to start with this approach before spending on the whole battery. I'll start looking at some local junkyards.
  6. PriusNoob86
    16
    Austin, TX
    I'll definitely start checking out what the junkyards have before I spend more than I need to. Thanks!
  7. pasadena_commut
    pasadena_commut Senior Member
    2,213
    661
    Southern California
    Maybe like LKQ, but not LKQ itself. They bought Green Bean battery in 2021 and since then every single Toyota pack from cars in their yards goes there. Probably true for Honda's and other brands too.
  8. Brian1954
    1,697
    662
    I just did a search at lkqonline.com for Prius hybrid batteries in the state of Texas and found many available to be purchased. Try searching yourself.
  9. MAX2
    MAX2 Senior Member
    1,436
    481
    101
    Third planet from the Sun
    3.8V this is junk.
    The module has 6 cells of 1.2v. min 7,2V
    If the cells are partially zeroed, the module is not working
    turbo5spd-prius and Brian1954 like this.
  10. pasadena_commut
    2,213
    661
    Southern California
    There are two available in the entire state of CA - in Stockton, which is 345 miles away. I actually asked a worker at the LKQ near me why there were never any packs and he told me that before they put the cars out they pull the packs and ship them out. When asked if I could request that they hold one if I reserved it ahead of time the answer was no.
  11. Brian1954
    1,697
    662
    Apparently, how LKQ operates in CA is different from how they operate in Texas and my home state of PA. There are very many Prius hybrid batteries available for purchase in PA.
  12. PriusNoob86
    16
    Austin, TX
    Hey Brian, do you know if LKQ leaves the batteries in the cars in the yard or do they pull them and keep them for sale separately? Of course I can't get through their automated phone system to ask that question. Just wondered if you had any experience with.
  13. pasadena_commut
    2,213
    661
    Southern California
    I'm going to go out on a limb here and say that they take the pack out. That's because they remove all the fluids and the 12V batteries, so it is hard to imagine they leave a lethal shock hazard in the cars.
  14. turbo5spd-prius
    turbo5spd-prius Junior Member
    71
    United States
    I've had both experiences. I changed one module and the pack lasted a couple of years till problems returned. I replaced a single module again and the pack failed within a month. I then replaced one more module plus a couple I theoretically didn't need to, but they had highest internal resistance of those remaining. No problem since.
    If you DIY, just go for all modules that stand out significantly. Do some live data recording if you have the tools/software to get a sense of which modules are odd in dynamic usage. Also note which ones may have internal resistance that stands out significantly as higher than most... these two categories overlapped in my case.
    I forgot to mention. I got a battery testing tool from Harbor Freight and ran it on all modules so the ones that didn't test to 100% got the boot. Just repeat and be consistent when testing vis a vis electrical contacts. So, I used 3 criteria to determine which modules to replace... but you have to have the pack apart for this test of course. Maybe just buy a couple more modules than the data gleaned from the tests above indicate you need.
    I got my modules on E-Bay.(E-pray as some call it).
    #14 turbo5spd-prius, Mar 4, 2025
  15. turbo5spd-prius
    71
    United States
    Junkyards know the packs are valuable so yes, they definitely take them out and sell them whole. If you're lucky you may be able to buy just a few modules.
    PriusNoob86 likes this.
  16. Brian1954
    1,697
    662
    I have no idea. I only visited the LKQ website.
    #16 Brian1954, Mar 4, 2025
  17. PriusNoob86
    16
    Austin, TX
    Thanks for the info
  18. PriusNoob86
    16
    Austin, TX
    This is great, thorough advice. I really appreciate it; I will probably go a similar route. Worth a shot with the DIY to possibly save scratch. Thanks again.
