Recommended dash monitor
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by catallaxy, Apr 14, 2025.
  1. catallaxy
    catallaxy New Member
    florida
    2014 Prius v wagon
    Dash monitor?
    At a minimum I want to have a monitor for engine temp, but what else should I be monitoring, and
    what monitor do you all recommend?
    51,950
  3. catallaxy
    florida
    2014 Prius v wagon
  4. PriusCamper
    PriusCamper Senior Member
    12,771
    5,174
    Pacific Northwest, USA
  5. MAX2
    MAX2 Senior Member
    1,436
    487
    101
    Third planet from the Sun
  6. Mendel Leisk
    41,464
    I'd recommend none. Had a scangauge connected for a few years, then it started giving the car fits: work-to-rule brakes, brake/traction warning lights, Check Hybrid System. Stopped using the SG, issues ceased.
  7. Brian1954
    Brian1954 Senior Member
    2,211
    869
    South Central PA, USA
    This is what I wrote two months ago in another thread.
    Here is one listed on Amazon. P10 display
    #7 Brian1954, Apr 15, 2025
  8. Dave1UK
    Dave1UK Junior Member
    66
    London, UK
    Active
    Personally purchased the hardwired OBD2 P10 as pictured (own dedicated monitor/screen). Got it from AliExpress rather than Amazon as they are both the same without the inflated x2 price/potentially wait a few days longer. Wanted something with its own dedicated display and no need to worry about turning it on/off or connecting, turns on with ignition.
    Nice and small can have it on the dash or slightly out of direct view in corner areas. Can set alerts for engine coolant temperature which I was mainly interested in.
    Have only had it and used it for a few days so can't comment on how long/well it'll last.
    This is the AliExpress link that I got it from:
    https://www.aliexpress.com/item/1005006247550817.html?spm=a2g0o.order_detail.order_detail_item.4.2506f19cKSk1H3
      File size:
      183.2 KB
    Brian1954 likes this.
  9. MAX2
    MAX2 Senior Member
    1,436
    487
    101
    The P12 has a more interesting design.
      File size:
      130.5 KB
    Dave1UK likes this.
  10. Dave1UK
    66
    London, UK
    Active
    I didn't come across the p12 assuming it's an upgraded version. Well I guess if the p10 ever stops working or whatnot may upgrade it!
    Either way they're both cheap and cheerful for their intended purpose if you're basically just after engine coolant temperature etc.
    Also like the RPM gauge even though the Prius dash already covers when using engine/battery. When it's on 0 RPM easier to tell (for me anyway) that electric motor is on.
  11. CR94
    CR94 Senior Member
    2,694
    1,173
    Northwestern S.C.
    I've had a ScanGauge II connected for over 5 years now, and never any such troubles.
    I normally keep it showing coolant temperature, engine speed, traction battery current, and either 12-v battery voltage (in winter) or traction battery temperature (in summer, when that's often a major concern).
