Recommended LED headlight conversion and headunit for 2018 Prius Two?
Discussion in 'Gen 4 Prius Accessories and Modifications' started by KRDucky, Mar 20, 2023.
  1. KRDucky
    KRDucky Junior Member
    30
    US
    2018 Prius
    Does anyone have LED headlight conversion kit recommendations for a base model 2018 Prius Two? As well as headunit upgrades (android auto/car play/mirroring (Waze)) for it? The larger the screen the better. Maestro RR/RR2 support for sure. I don't really care about the energy monitor since I can look at in on the dash screen.
    I also want to figure out a good Qi charger setup for it.
    SM-G981V ?
  2. Pulse07
    Pulse07 Active Member
    273
    140
    East Bay, California
    2020 Prius
    XLE AWD-e
    I believe the headlight are already LEDs.
  3. Hidyho
    Hidyho Senior Member
    2,699
    531
    2018 Prius
    From 2018 Brochure:
    #3 Hidyho, Apr 18, 2023
  4. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,801
    2017 Prius c
    I strongly suggest that you leave the headlights ALONE.
    IF.....you really do a lot of driving at night in rural areas, add some driving lights.
    The improvement will be MUCH better.
    Doug McC likes this.
  5. PianoBench
    PianoBench Member
    154
    95
    San Francisco
    Amazon.co.jp: VALENTI TT50PRI-HC-1 HID 50 Prius Jewel LED Tail Lamp, REVO Series, Half Red/Chrome : Automotive - I recommend these for the rear tail light conversion.
    【Rakuten Ichiba】 VerticalArrow LED High Mount Stop Lamp Prius 50 Series TOYOTA PRIUS 3rd lamp: JACKPARTS - This is what I recommend for the rear tail light center.
    【2023年最新】プリウス ヘッドライト 50の人気アイテム - メルカリ (mercari.com) - You can try mercari for a bunch of modded headlamp conversions.
    Good luck! Please post your results here !
  6. KRDucky
    30
    US
    2018 Prius
    Can you define the difference between "driving lights" and headlights? I do a lot of South Texas driving.
  7. Pulse07
    273
    140
    2020 Prius
    XLE AWD-e
    I think "driving lights", you are referring to your Daytime Running Lights (DRL). The come on as soon as you start the car. And I believe in some models, they turn on as soon as the handbrake is off. "Headlights" are also called low beams, thats what you use at night.
    Hybrid4Life likes this.
  8. sam spade 2
    7,035
    2,801
    2017 Prius c
    No, NO. Not even close.
    I am talking about separately mounted extra auxiliary driving lights that can be wired to the high beam circuit or put on their own switch.
    That way, you will not run the risk of mucking up your regular headlights and making them obnoxious and possibly illegal.
  9. Doug McC
    Doug McC Senior Member
    1,068
    413
    Midwest
    2022 Prius
    Before you mess with your headlights you might want to check out the replacement cost for them. Secondly, your headlights (and the ones on most cars since at least the 1950’s) consist of low-beams and high-beams. And from the information that was posted on this thread, you have LED headlight assemblies, so you are apparently trying to convert to something you already have! Is it possible that you just haven’t figured out how to turn on the high beams yet?
    Hybrid4Life and Pulse07 like this.
