Recommended preventive check-ups/maintenance
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by Phil Viana, Jul 24, 2017.
  1. Phil Viana
    Phil Viana New Member
    Austin, TX
    2015 Prius c
    I've had my 2015 Prius C One for about two and a half years now. It's at 48,000 mi.
    So far I've done most the oil changes at my dealership + 2 at my mechanic. Never had to touch anything else. However, I'm sure the time is coming when I'll have to start worrying about tires, parts, AC care, etc. I'd like to know the opinions and suggestions of you Prius experts on what preventive check-ups and maintenance I should do at this point. Like I said, it's 2.5 years old @ 48,000 miles. Suggestions may include, but not limited to:
    - Tires
    - Suspension
    - Hoses
    - Cooling system
    - Oil, filter, etc.
    - AC hygiene
    - Polishing/paint
    - Brakes
    - Transmission
    - Anything else you can think of :-D
    Thanks in advance,
    Phil
    49,500
    welcome!
    1) do the tires when tread wear is unacceptable.
    2) oil and filter every 10k.
    3) polishing/paint as needed.
    4) inspect/lube brakes every 30k.
    5) tranny oil every 30k.
    6) start checking your 12v with your oil and tyre pressure
    7) follow the maintenance manual for everything else.
    8) all the best!(y)
    Phil Viana and Raytheeagle like this.
  3. WilDavis
    WilDavis Senior Member
    2,492
    2,153
    49
    […slowly gets up on soap-box] Read all you can on preventative maintenance of hybrid batteries and Hybrid Automotive Prolong Grid Charging [/…slips and falls off soap-box:eek:] (…bloody OUCH! :whistle:)
    BTW Welcome to PriusChat! The perfect place to learn all you will ever need to know about your Prius, but be warned! It's ADDICTIVE! ;)
    Phil Viana likes this.
  4. Mendel Leisk
    38,729
    ^ Whoa: still waters run deep. I can't think of anything else. Especially with #7, covers everything.
