Recommended psi for touring model?
Discussion in 'Gen 2 Prius Main Forum' started by neon tetra, Apr 26, 2008.
  1. neon tetra
    neon tetra Member
    309
    I've read a lot of threads on here regarding tire pressure, but since the touring model has different tires, is there an ideal pressure for it?
  2. JimN
    JimN Let the games begin!
    7,028
    1,116
    South Jersey
    There is no "ideal" tp. You need to find a balance between ride, handling, and economy that you can live with. If you running a pressure under the max as printed on the tire then try increasing it to the max.
  3. lefat1
    lefat1 Fat Member
    1,476
    47
    Sunny S. Florida
    i've been satisfied with 40f, 38r for about 4 months now..these are on the bridgestone turanzas
  4. rpiereck
    rpiereck Regenerator
    289
    I put 45 psi f/r on my Touring and find the car very comfortable this way.
  5. charansr
    charansr Member
    107
    Concord CA
    I use 44/44 (F/R). You can feel a slightly bumpy ride on rough roads. But other wise rides great!
  6. greenlv
    greenlv New Member
    29
    Las Vegas, NV
    I've also read many of the threads related to tire pressure. Can someone please explain the reason behind setting the front tires 2psi higher than the rear tires? Does it really make a difference?
  7. rigormortis
    rigormortis Active Member
    1,340
    26
    san jose, ca
    i think toyota reccomends it because there is more weight in the front, thats my guess
