Recommended rotors for 2011 prius
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Gnarly, Nov 27, 2018.
  1. Gnarly
    Gnarly Member
    139
    Can I simply do a Google search for 2011 Prius rotors and expect that results are close?
    Does anyone have a particular brand they purchased.and would you have that link?
    Thank you.
    49,504
    i would guess most use oems. you can google than pick an online dealer.
    how many miles on your car?
    Gnarly likes this.
  3. JC91006
    16,482
    8,400
    You're in California, what could be wrong with the rotors?
  4. working1
    working1 Active Member
    121
    111
    Used these to replace the rusty OEM's:
    Front: WAGNER BD180387E
    Rear: WAGNER BD126558E
    Black E-Coat on non-braking surface to prevent rust and corrosion. The OEM's do not have this.
    Robert Holt, Gnarly and JC91006 like this.
  5. Gnarly
    Gnarly Member
    139
    Huh?! I didn't think it was proper to answer a question with a question. I'm not sure what the point was to this comment. Do you have a problem with people in California?
  6. bisco
    49,504
    we're just wondering why you need rotors. pretty unusual on a 2011 unless your in the salt belt
    Gnarly likes this.
  7. Threej
    Threej Member
    99
    99
    Portland, OR
    I think the point is that due to the prius's regenerative braking taking place in the CVT, the brake pads, and in turns rotors, get a lot less wear and tear than normal cars. Given that California generally doesn't have need to salt their roads, the #1 source of rust and corrosion also isn't an issue.
    Given that everyone here is super nerdy about anything that could ever possibly be wrong on a prius, he probably just wanted to know what your conditions were that lead to this.
    Gnarly likes this.
  8. Gnarly
    Gnarly Member
    139
    Sounds good guys, thanks for the explanation.
    The mechanic told me that both rotors at the back needed to be machined. I looked at his itemized list and it would've been cheaper to just replace than to have machined.
    All is good anyways because I went to another shop and they gave me a better price. Also, the 1st mechanic was charging $214/hr. for labor.
    Bay Stater, m.wynn and bisco like this.
  9. bisco
    49,504
  10. m.wynn
    m.wynn Senior Member
    684
    1,226
    Queensbury, NY
  11. ASRDogman
    ASRDogman Senior Member
    6,093
    3,273
    $214 and hour!!!!! That is INSANE!
    You could take an automotive course and at community college for that price and learn how to do it yourself! It's rare the rear rotors need replacing. Also rare they get warped. Did the pads wear
    down to the metal destroying the rotors? Maybe they didn't need to be replaced or machined/turned.
    When I install new pads with old rotor I just take some rough sandpaper to them to clean them up.
    Bay Stater likes this.
  12. TMR-JWAP
    TMR-JWAP Senior Member
    6,231
    5,934
    Columbia, SC
  13. Mendel Leisk
    38,732
    I was gonna ask if you measured the thickness and runout, post the spec, but sounds like you've got all the answers.
  14. Gnarly
    Gnarly Member
    139
    I was talking about this at dinner with my wife and she told me that the guy bought the business recently and that's probably why labor cost is high. IMG_20181130_081600.jpeg IMG_20181130_080840.jpeg
  15. Mendel Leisk
    38,732
    Yeah front and rear rotor thicknesses are both very close to new. I rarely if ever replace rotors, just pads.
    Front:
    Rear:
    Bay Stater, Threej and bisco like this.
  16. Gnarly
    Gnarly Member
    139
    Bay Stater and Mendel Leisk like this.
  17. Mendel Leisk
    38,732
    The other criteria is runout, which is also in the attachment. Bottom line though, even if runout is near the limit, if you're not feeling a distinct pulsing when braking, it's fine.
    Seems like a lot of people changer rotors because "they're rusty". Rotors are not stainless steel, and for sure any parts not constantly brushed by the pads will rust, but it doesn't effect operation.
    Be careful with the rear brakes: there's a cross-pattern on the caliper piston face, that must be correctly oriented (see attachment), and well seated thus, to prevent brake drag, uneven wear, all sorts of mayhem. If the mechanic is not experienced with 3rd gen Prius, print the attachment out for him. It's good to get the pistons properly oriented, everything installed, brake pedal pressed multiple times to seat everything. Then test drive. Then (and only then) apply/release the parking brake a few times. Then raise the rear and verify the wheels are turning semi-freely, able to spin a revolution or two with a good push.
    Also, it's really good to disconnect the negative battery cable before disassembling anything: if the brake pressurization happens while a caliper is off a rotor, there's a good chance it'll push a piston right out.
    Also, I'd be inclined to not open bleed screws when pushing piston back to accommodate new pads: the car may throw a code. And front or rear: do multiple brake pedal pushes when done, to seat everything, before reconnection of negative brake cable.
    #17 Mendel Leisk, Nov 30, 2018
    Bay Stater and Threej like this.
  18. bisco
    49,504
    don't think this is a diy job
    byop = bring your own parts
    Raytheeagle likes this.
  19. Mendel Leisk
    38,732
    I'm thinking an unwary mechanic could create mayhem. And that's frustrating. Just valet parking, the car can get messed up.
    Bay Stater, bisco and Raytheeagle like this.
  20. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,482
    Bay Area, California
    2019 Prius Prime
    Like lose your key:mad:.
    Had that happen 4 years ago and to this day when we go back to the same place, the manager still remembers:cool:.
    Bay Stater, Mendel Leisk and bisco like this.
