Recorded Gen II reliability
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by offib, Sep 5, 2017.
  1. offib
    offib Member
    162
    95
    Dublin
    Four Touring
    Irish Independent has put out an article regarding Ireland's vehicle road worthiness test or NCT, similar (and less advanced) as the UK's MOT.
    It focuses on how new cars pass the most first time, old cars fail the most first time, nothing special. However;
    ''...for cars dated 10 years or older, the Toyota Prius has the best first-time pass rate at 62pc. Additionally, Toyota occupies four slots of the top 10 first-time passes for cars 10 years or older.''
    Well, I wasn't so lucky. I had to pay an extra 20 something euro for another booking because it had a rusty, rear brake pipe.
    I can attest to that given that they perform flawlessly in the test. Aside from impeccable reliability, it's mainly because the NCT isn't bothered with training their staff to activate maintenance mode, as the emissions test require a readable tachometer and the ability to high-idle at 2100 rpm. Our cars can't do either of that.
    Brakes can't be tested properly either because of the regen, so it always appears spotless - that or the test requires a rolling road which brings us back to disabling the ESC with maintenance mode.
    How different makes of car rate in the NCT - and the model that performs the worst every year - Independent.ie
    Mess around with it for yourself: Tableau Public
    The crappy, euro TDIs and Ford's TDCis aren't doing too well with age - surprise surprise.
    49,713
    around here, they just plug the computer into the obd plug and check past performance.
  3. offib
    offib Member
    162
    95
    Dublin
    Four Touring
    So they even check the emissions with the OBD port?
    49,713
    yes, that's basically what they are checking. no more warming the engine or putting a hose on the tailpipe, it's all in the computer memory.
    offib likes this.
  5. offib
    offib Member
    162
    95
    Dublin
    Four Touring
    That's good to know, and knowing that the Irish government right now is incapable of looking past the austerity it made for itself, I doubt the NCT centres will be given more funding and updating anytime soon.
  6. 8404HMC
    8404HMC Junior Member
    24
    30
    Martinez, CA
    had to bring my 2009 Prius in for SMOG for the first time this year (before it got totaled) and was surprised how quick it went... nothing hooked up except the ODB. I thought it was pretty cool actually! Past with flying colors at 225,000 miles!
    bisco and offib like this.
  7. bisco
    49,713
    whoa! how do you accumulate that kind of mileage? :eek: i wonder if the prius gets a pass like in ireland, due to the operating parameters even in the computer records. but i do believe cali is very strict on catalytic converter operation.
  8. offib
    offib Member
    162
    95
    Dublin
    Four Touring
    Well, emission regulations would have to be in compliance with EU law - which is considerably less stringent than the US' until 2015. Unfortunately (for nice cars like big Citroens or 1990s Mazdas as my family seen), when an engine, often diesel now, knocks itself to pieces just enough, it would fail its NCT requiring an engine rebuild which would easily cost more than the car's worth.
    If you still fail and it's just the engine failing (the O2 sensor, CAT and DPF are in good working order), then what would throw you off is Carbon particulates (i.e soot). Many people I know (most of them as business owners infact) have passed their diesels through the NCT by running a litre or gallon of petrol through the system to ''clean off'' any gunk in the fuel lines, injectors, etc.
    #8 offib, Sep 7, 2017
