Recurring P0446 code
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Draken, May 1, 2014.
  1. Draken
    Draken Junior Member
    Hello all, been having an issue with my 2005 Prius (186k miles) throwing the P0446 error code (Evap Emission Control System Vent Control Malfunction). It was in the shop twice last year for this. First time, diagnostic was clean, they replaced the gas cap, reset the light and sent me on my way. Happened again a day or two later. Back in shop, again diagnostic was clean. They contacted Toyota who had the tech manually cycle the valves. One was sticking every now and then, they replaced it. Now, just about a year later, code comes up again. Back in shop, they detect a minor leak, say gas cap wasn't seated. Cleaned it up, reset the light and off I go again. Week later, code is back. Tired of throwing money at the dealer so they can play eenie meenin minie mo trying to fix this. So I got a bluetooth ODBII scanner and run Torque Pro on my Android phone. I've attached the logs (CSV) from a trip home, about half way on that trip, the MIL came on again for the same code. Can anyone look at the sensor output and give me a better idea of what is going on? The Evaporative System Vapor Pressure seems to swing wildly, at least to me. Any help you all could provide would be greatly appreciated, and my wallet thanks you too!
    Cheers,
    James
  2. Draken
    I should also mention that I click the gas cap two clicks when putting it back on after refueling.
  3. Patrick Wong
    18,200
    6,471
    This is the full list of suspect items with DTC P0446. Consult techinfo.toyota.com for repair manual info if you wish to dive deeper:
    Fuel tank cap is incorrectly installed
    Fuel tank cap is cracked or damaged
    Vacuum hose is cracked, blocked, damaged or disconnected
    Open or short in vapor pressure sensor circuit
    Vapor pressure sensor
    Open or short in EVAP VSV circuit
    EVAP VSV
    Open or short in CCV circuit
    CCV
    Open or short in VSV for purge flow switching valve circuit
    Fuel tank is cracked or damaged
    Charcoal canister is cracked or damaged
    Fuel tank over fill check valve is cracked or damaged
    ECM
  4. Draken
    I'm hoping someone with more knowledge on this subject can look at the ODBII logs and help narrow it down a bit, as that is a lot of stuff to check/replace trying to fix this issue.
  5. Patrick Wong
    18,200
    6,471
    The reason that I provided the long list is to show you that many issues could cause the problem. After all, if it was so simple to fix the dealer tech would have already done that by now.
    If you are truly serious about doing something about the problem, you need to do the following:
    1. Buy Mini VCI, which runs on a Windows XP or Windows 7 32 bit OS laptop
    2. Subscribe to techinfo.toyota.com
    3. Follow the detailed troubleshooting steps (there are ten activities) associated with P0446, which requires you to remove and inspect several components associated with the fuel tank.
    4. When you see the troubleshooting tree involved, you will understand that for a complete job, the dealer service department could easily charge you for 4 hours of labor not to mention the parts markup. Is it worth it to you to save $500+ by DIY?
    5. Or of course, you could live with the car as-is.
  6. Draken
    Sounds a bit too involved for my level of car knowledge. Is there any long term harm with ignoring the MIL and resetting it myself before taking the vehicle to the dealer for any service I have them perform? I need to get about 2 more years out of the vehicle but currently don't have funds for long, drawn out and potentially expensive troubleshooting and repairs for the P0446 code. But I'll do what I have to if it means the health and safety of the vehicle.
    Thank you
  7. Patrick Wong
    18,200
    6,471
    There is no impact on vehicle health or safety. The impact is on the environment, as the fuel tank potentially is allowing gasoline vapor into the atmosphere.
  8. Draken
    Thank you, appreciate the information!
  9. CatsAreGods
    CatsAreGods Junior Member
    46
    But if Draken keeps the car indoors and gasoline fumes build up, it could be dangerous in that case.
    Nexus 4 ?
  10. Draken
    Shouldn't be any more dangerous than a 70's or 80's era vehicle kept in a garage. Or a lawn mower and other gas powered lawn equipment.
  11. 299K
    299K Junior Member
    30
    Cleveland, OH
    Hello all.
    Just started having this code on my 2005. Estimated 500k on her. When this code triggers the check engine light, it causes the ICE to run almost all the time. Did anyone ever figure out the solution to p0446? For now I just erase the code when the check engine light comes on, no other issues. I do have the spoofer installed, put it in during this past winter, no check engine light till the weather started getting warmer here.
