Red arrow in energy monitor
Discussion in 'Gen 4 Prius Main Forum' started by baysidefish, May 26, 2021.
  1. baysidefish
    baysidefish Junior Member
    33
    usa
    2021 Prius
    LE AWD-e
    I have a 2021 LE AWD-e, there was a Red arrow in energy monitor for about 2 secs and a warning sound. I did not have enough time to take a pic.
    I am not sure if this information is enough. thank you
  2. Tideland Prius
    16,532
    What kind of sound? One beep? Two beeps? Three beeps? Continuous beep while the red arrow flashed?
    jerrymildred likes this.
  3. jerrymildred
    jerrymildred Senior Member
    11,517
    14,147
    Tampa, FL
    I think I, at least, would need more info. I never use the energy monitor. It has arrows that flash & move around, but there are no buzzers associated with the energy monitor. Some things that will trigger a buzzer are:
    Blind Spot Monitor (BSM)
    • Brake system
    • Downshifting
    • Lane departure alert
    • Open door
    • Open moon roof
    • Parking assist sensors
    • Pre-collision warning
    • Radar cruise control
    • Seat belt reminder
  4. baysidefish
    33
    usa
    2021 Prius
    LE AWD-e
    There was a continuous beep and the red arrow showed up around this area. (see pic) I did not find this in the manual.....thank you
  5. FuelMiser
    FuelMiser Senior Member
    1,349
    928
    Monument, CO
    What were you doing at the time this occurred? Was the car READY or just powering up? Were you shifting out of Park? Was the door open or closed? Was the car moving? The car will warn if you get things out of sync: doors closed, brake pressed, power button pushed, READY illuminated and one "ding", shift out of Park with brake still depressed. Also, if you open a door with car not in Park, it will alert you.
  6. jerrymildred
    11,517
    14,147
    Tampa, FL
    Are you sure it wasn't this? ^
    Normally, if there's a beep, a message will take over the MID and you won't even see the energy monitor for a few seconds.
    Then again, your AWD may have features the 2WD does not have.
    Tideland Prius likes this.
  7. baysidefish
    33
    usa
    2021 Prius
    LE AWD-e
    I was driving at the time, nothing out of the ordinary. I was stuck in traffic about 6 miles or so..thanks
  8. baysidefish
    33
    usa
    2021 Prius
    LE AWD-e
    Mine shows yellow arrows. thanks
  9. jerrymildred
    11,517
    14,147
    Tampa, FL
    Yes, just like the manual says, from the battery is yellow. From the ENGINE to the wheels is red.
