Red Bullet Works!
Discussion in 'Gen 2 Prius Technical Discussion' started by edthefox5, Oct 30, 2020.
  1. edthefox5
    edthefox5 Senior Member
    10,096
    4,805
    Clearwater, Florida
    So I have seen the Red Bullet OIL VVT Valve replacement mentioned in this forum mostly the G3/G4 forums and other Car forums with good reviews so thought I would try it with my bought new G2.
    Its a solenoid oil control valve for the VVT that allows greater oil to flow that advances intake timing much faster than stock at a given pedal position. That scenario works really well on an atkisson motor. It works.
    One thing I noticed is its hitting much higher RPM than stock if driven hard.
    So if you get on it hard you could maybe over rev the motor the atkisson cycle is a lower rpm higher torque motor but not really an issue as its quickly obvious how much the engine is revving more than normal. Just surprised me.
    Works really good there's definitely some unleashed power in this car. You may not notice it creeping around town but on the highway its a major improvement in passing cars etc. You really notice it in CC when you go up a little rise its got some torque there.
    Wife noticed the power too (that's what she said lol) I pummeled the car today with its new battery it was fun.
    And no pinging!
    I did notice on my CC I got excellent mpg's too. And it was not flat road still got 58 mpg's.
    $123 delivered.
    If you mostly drive on the highway I highly recommend it. Its super easy to install just take the air cleaner box off (glad I did I found the air filter box underneath throat clamp had loosened up) and its one 10 MM bolt to remove it. Pull it out and bolt in the new one. Everything is right there in the open. Takes 5 minutes.
    When i took the air cleaner box off I intended to clean the throttle body as I haven't for about 40,000 miles but it was squeaky clean. That's high performance oil there Redline 10-40. Absolutely no sludge whatsoever dumping into the pcv like dino oil. You can see the pcv hose inlet hole in the side of the throat and its clean as can be.
    Its a very clean running motor.
    If your eating oil becasue of stuck oil rings your using some really crappy oil like dealer vat oil.
    It had the standard atkisson oil pool at the bottom of the TB. That pool at the bottom there has 4500 miles on it.
    #1 edthefox5, Oct 30, 2020
  2. mr_guy_mann
    mr_guy_mann Senior Member
    3,441
    1,493
    NJ-USA
    If you like it for what you paid then great, it works for you. I would need data before I considered any product like that. There would have to be A-B-A testing (back to back tests of a new OE solenoid vs the Red bullet) with at least data log of rpm, cam position, vvt control, VSS, and throttle control/ position under identical road acceleration.
    Preferably there would be osilloscope captures of cam and crank sensors and vvt solnoid control.
    MPG results are all well and good but realistically there are too many variables to base results on that.
    Without reliable data that you can compare and analyze, all the "testimonials" are just marketing BS.
  3. ChapmanF
    15,489
    It warms my heart not to be the only one pointing that out.
    Yosarian likes this.
  4. Hydrocket
    Hydrocket Member
    78
    39
    CA
    Technology
    I recall a test in another Prius forum (C model maybe? ) where they did back to back to back mileage tests among others (1/4 mile and acceleration too I believe)
    While anecdotal and not scientific...if it's one thing I've noticed, it's that Prius owners who drive the same route day in, day out, week after week know EXACTLY what their recurring mileage is and seem to be particularly sensitive to any changes in mileage.
    I suspect those people could tell if there was any mileage to be gained by such a device.
    I suspect I could too since I drive the same, boring old route every..single..day. I can tell you what my MPG is going to be BEFORE I even put gas in the car, such is the repeatability of the Prius! LOL (wide temperature changes excluded)
    I suspect if it's a minute change I wouldn't notice. But something like 5-10 percent either way, would stand out immediately.
    #4 Hydrocket, Nov 1, 2020
    edthefox5 and Threej like this.
  5. ChapmanF
    15,489
    It would be a boon to PriusChat if more of those exactly-mileage-knowing Prius drivers would in fact calculate the standard deviation of their results over longish periods and publish them here and compare to the magnitudes of the changes they are so particularly sensitive to.
    Yosarian and Another like this.
  6. Hydrocket
    Hydrocket Member
    78
    39
    CA
    Technology
    I used to do stuff like that frequently. In particular to my modded cars, logging 100s of dyno runs along the way. But someone would always find something to complain about when I'd post results. Can't please everyone! :) I just do it for me now.
    I once did an exhaustive test (as in I was exhausted when I was done) of using acetone as a fuel additive in an old Toyota Echo. Was exhausting because to remove as many variables as possible I shifted gears at the same RPM, drove the same route, etc. Since the Echo was a fuel sipper, it took FOREVER to do the back to back to back. Plus the car was boring to drive. I was exhausted when done! :)
    I think the most interesting/unexpected one I did was a back to back oil test. An oil rep GUARANTEED I'd make more HP using his oil than my already high quality oil. I called BS. He'd pay for dyno and oil if he lost. I'd pay for it all if I lost (oil was expensive). We agreed on a deviation run to run (I had tons of data, so I knew what the car made run to run to run). I lost the bet. :(
  7. edthefox5
    10,096
    4,805
    Clearwater, Florida
    Did not buy it for fuel savings bought it for a little more power. Not going to see any fuel savings in my car now as its a lot more fun to drive
    and I'm in the gas more now.
    Not a big difference from 0-60 little faster but that mid band power curve at 50 miles and hour and you need to pass a car quick there's a big difference.
    My 07 is unique it has a really good engine and a brand new hybrid battery so YMMV.
    But what do I know I have only owned the car 13 years.
    Max Taiwan, m.wynn and Aaron Vitolins like this.
  8. Aaron Vitolins
    Aaron Vitolins Senior Member
    1,612
    1,144
    Franklin TN
    Ed I’ve followed you for years, I always appreciate your write ups and comments!
    you’ve got me thinking I might want to try one of these Red Bullets...
  9. AzusaPrius
    AzusaPrius Senior Member
    1,843
    811
    I can say having one of these will change they way the car feels.
    Very light and quick is what I would say if I had to describe what it feels like having one installed.
    There will always be some who do not think it works or it is snake oil.
    Those are the ones who do not need it and could not tell the difference if it was installed.
    Like it has been said, really knowing how the car drives will tell you it works.
    PriusCamper and Max Taiwan like this.
  10. edthefox5
    10,096
    4,805
    Clearwater, Florida
    I agree 100% it has changed the way I feel about the car. Its light on its feet now. AIso much smoother now you dont really feel the transition from the engine start & stopping all the time as its gets up and goes now when it starts that lag when you pull away from a light is much better now.. Much much smoother my wife said the same thing.
    But my situation with a g2 is unique its got a brand new battery and also the engine is in really good shape so i had something solid to start with. Most people on here are just trying to get there hybrid battery sorted out so i understand that.
    Max Taiwan likes this.
  11. Moses Bruh
    Moses Bruh Member
    97
    29
    Question, if my engine eats oil (hopefully its a valve cover gasket issue that i can fix) and I get an Red Bullet in there, would the chances of oil consumption increase just on the fact that it releases more oil at once?
  12. edthefox5
    10,096
    4,805
    Clearwater, Florida
    Well to perfectly honest if my car was eating oil I would not buy the Red Bullet because you will be driving the car harder and it may exacerbate your oil eating issue. You will drive the car harder because it goes a little faster its more fun which is a real nice change for this mutt.
    I have not done a mileage test on this though as that's not why I bought it.
    If its an oil eater I would just take it easy on the car.
    donbright and Aaron Vitolins like this.
  13. ChapmanF
    15,489
    The claim made for this product has consistently been:
    • (a) it makes valve timing changes happen faster than with the stock valve, and
    • (b) because of (a), happy things with performance and drivability ensue.
    Last Wednesday, mr_guy_mann put up the first (known to me) direct test of whether (a) happens. The test was done by scoping the crankshaft and camshaft sensors, which had already been identified two years earlier as the way it would have to be done. Data from OBD-II would not suit the purpose because of the delays in polling OBD-II and getting replies.
    The work does have (for now) one methodological weakness, small sample size; it was well designed in taking multiple runs with each type of valve, but having purchased only one sample of each type, it cannot (by itself) rule out whether the single sample of any of the valve types was a dud. But it is a very good start on getting some basic information about this product that has been overdue for a couple years now.
    Yosarian and dolj like this.
