Red Low Coolant Light Warning
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by h-dogg, Jan 9, 2022.
  1. h-dogg
    h-dogg Junior Member
    44
    South Bay
    My wife's 2012 Prius v (133k miles) had the red low coolant light warning on for <1 minute and went away while driving on the freeway. The car drove normally, so didn't noticed anything changed from the warning.
    I checked the next day and noticed that the engine coolant reservoir container had coolant spot residue everywhere and some on the passenger engine side. I figure the pressure must've released some coolant when driving. I cleaned the area and drove around and didn't notice any leaks or warning light.
    Have any of y'all experience this? Water pump ready to go? Head gasket going?
    Oil level is good and clean. The only issue I see is slow oil seepage in maybe timing chain tensioner area (always caked with oil).
    I'll start monitoring the car every few days to see if I get leaks on the reservoir area. If so, I'll make an appt. with a mechanic.
    Thanks!
  2. ChapmanF
    18,521
    I don't believe that there is such a light. If you saw a red light shaped like a thermometer, it is a high coolant temperature light.
    Or, if you're positive it was a low coolant light, could you try to describe it in some detail, its shape or its location on the dash?
    I don't believe the car has any coolant level sensor that could be used to operate a low coolant light.
  3. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    AND.....through out his whole description of what he did and what he observed......
    Never once did he say anything about the actual level of coolant present in the bottle or the actual radiator.
  4. rjparker
    rjparker Tu Humilde Sirviente
    10,484
    6,572
    Texas Hill Country
    Yes you likely have a water pump going out.
  5. h-dogg
    44
    South Bay
    @ChapmanF: You're right, it was the high coolant light. I checked and it seemed to be at the Low line and filled it right to the Full or crease in the bottle.
    What's the typical life of a water pump?
  6. sam spade 2
    7,035
    2,804
    2017 Prius c
    He never said that.
    And there is no coolant level light......neither high or low.
    Are you trying to say "high coolant temperature" ?
  7. ChapmanF
    18,521
    I figured that was probably what h-dogg meant.
  8. rjparker
    10,484
    6,572
    Texas Hill Country
    If you are trying to be helpful, try to realize you might know more than the new guy.
  9. Tim Jones
    Tim Jones Senior Member
    1,759
    565
    SE Texas
    2011 Nissan LEAF
    Might be the head gasket
