Red Triangle after 12v battery replacement
Discussion in 'Generation 1 Prius Discussion' started by Anna Payesko, Oct 4, 2024 at 8:22 PM.
  1. Anna Payesko
    Anna Payesko New Member
    Big Island
    2001 Prius
    I just got my 01 prius back after a month of not driving it. I lost all my keys and had to get the ecu replaced at the dealership and they replaced my 12v as well because apparently the one the previous owner had in the car was aftermarket. I just got the car back three days ago and its been driving totally fine since then but the red triangle came on when I was driving home this morning. I pulled over and checked under the hood and checked under the car but nothing looked seriously wrong and I didn’t notice anything wrong with the way it was driving. It was only less then a mile back to my house so I just drove it home carefully, nothing seemed wrong with it on the drive back. Called the dealership and they said they would read the codes and fix it if it was an issue with the battery but when I went to take the car in the warning light had gone away. It had been about 3 hours since it came on at this point. Is this likely an issue with the battery or could it be something thats come up with the car sitting so long? I dont think its the hybrid battery because the one in this car was replaced before i bought it, though i dont know at what mileage. Ive been paying attention to the hybrid battery display the past few days and it seems to be acting normal. Should I keep driving the car until the triangle comes back on and they can read the codes? Any ideas on what the issue could be?
  2. Tombukt2
    Tombukt2 Senior Member
    10,086
    1,738
    Durham NC
    Keep driving the car maybe find yourself a cheap scanner that you can keep with you so you're not worrying with the dealership and foolishness to be honest with you it sounds like you may have the hybrid isolation fault which if you have a voltmeter that reads DC volts you can measure between the bottom bolt that holds the fuse in the hybrid safety plug and the frame of the car and the voltmeter should count down to zero DC volts not 40 not 60 not 35 but zero If any other number is displayed you have battery voltage leaking to the frame of the car which is the grounding point for your 12 volt battery not an ideal situation and can make the triangle come on usually when this happens the car won't restart till you clear the code so it may not be that or it may be very intermittent it's worth a check given the fact you don't know when the hybrid battery was replaced you don't know with what a brand new hybrid battery doubtful this is one thing that people don't like to spend money on and don't want to hear about a 2000 plus dollar battery so it is one of the last things that gets dealt with or it gets patched with Band-Aids rather than truly fixed or replaced It's worth a check it's a long shot a code reader is a good thing for you to have and one of the best $80 things you will buy for your car I would certainly be looking to get one an AP200 which is been discontinued is a nice little tool for your car and it's relatively inexpensive as scanners and things like this go it would be a very wise purchase
