Red triangle and brake Regen message
Discussion in 'Gen 2 Prius Main Forum' started by Wrecit, Nov 13, 2022.
  1. Wrecit
    Wrecit Active Member
    177
    113
    Pittsburgh
    2001 Prius
    I
    Ok car is running fine with no noticeable issues. In the past 2 days the red triangle will flash on and the top of the screen will say something about brake Regen system not working.
    The light and message are on for literally less than a second and the monitor still shows that it is doing Regen. Mpg is same as it has always been.
    Any idea what I am looking at?
  2. dolj
    dolj Senior Member
    8,554
    4,345
    Wellington, New Zealand
    I haven't seen that before. Are there any codes if you do a full system scan?
  3. Wrecit
    177
    113
    Pittsburgh
    2001 Prius
    I
    Only have Dr Prius to scan currently and no code. Will go to AutoZone tomorrow
  4. dolj
    dolj Senior Member
    8,554
    4,345
    Good idea, Dr. Prius is a bit limited in what codes it can show.
  5. PriusCamper
    PriusCamper Senior Member
    13,051
    5,304
    Pacific Northwest, USA
    Try "Car Scanner ELM" app to see if there's error codes. Usually a brief flicker of red triangle doesn't logged a code. Only time I had similar symptoms of flickering red triangle was during a hard braking event at a stop light and it turned out the only problem was the car was dangerously low on motor oil.
  6. Wrecit
    177
    113
    Pittsburgh
    2001 Prius
    I
    Camper ran across the possible oil issue in search last night. Am due for oil change so I checked. 2 qt low grrrr. Been a dream since adding and have over 100 miles on it tonight
  7. PriusCamper
    13,051
    5,304
    LOL... It's easy to neglect these cars because they're so reliable. Yet again the problems you can have with Prius are mostly ones that happen from neglect rather than unfair surprises... As my profile quote says on here for past 10 years: "My Prius doesn't have anything wrong with it... Should I be worried?"
