Red triangle and check engine sign
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by JamesMN, Jun 17, 2021.
  1. JamesMN
    JamesMN New Member
    Mn
    I have a 2009 Prius. Recently it shows red triangle and check engine sign. I went to a shop got a scan. It says the cooling of the battery is the problem. Not sure it is the fan or coolant too low? Appreciate help
  2. rjparker
    rjparker Tu Humilde Sirviente
    10,158
    6,316
    Texas Hill Country
    The hv battery is air cooled with a fan. Probably it is failed or blocked.
  3. JC91006
    16,769
    8,567
    is the problem an inverter pump failure? If you went to a shop that left you thinking it's either coolant or fan, it probably wasn't a mechanic shop?
  4. Kadir
    Kadir New Member
    Netherlands
    if cooling of the battery is the problem then cleaning the hybride battery fan might help. there are videos on Youtube explaning how to do this if you are a handy person.
