Red Triangle and Code P0AFA causes?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by 2manycruisers, Oct 22, 2018.
  1. 2manycruisers
    2manycruisers Junior Member
    Maryland
    I have a 2006 Prius with 165,000 miles. I put a new OEM Toyota hybrid battery at the beginning of June and the car has run as normal. A couple weeks ago after maybe 5 minutes on the road, we got the red triangle of death and assorted other lights. This was maybe the coolest weather we've had in a this fall (in the 50's). So we turned around and drove home. I plugged in my ScanGuage and found P0000. I reset it and the car was fine for about a week (the weather was a little warmer). One cool morning my wife started the car and the red triangle and other lights came on again, so she didn't drive it. I was leaning towards a failing 12V battery since it seemed to correlate with the colder weather. When I came back to town, I checked the codes and this time was P0AFA. I reset the codes and drove it tonight with no lights or codes coming on. However, it doesn't seem to be running properly. The IC engine ran constantly, but the MFD did not show charging when stopped. It went back and forth between charging and assisting while driving, but the battery level indicator did not move. It stayed about 3/4 full charge in stop and go about 4 or 5 miles each way.
    I installed the hybrid battery myself. I did not use a torque wrench on any of the connections. It came with new leads from the battery to the junction. I did not have to mess with any of the bus bar connections except to connect the new leads. I have not checked for any corrosion on the ECU connectors or other locations as I read in some threads (those seemed to have immediate and not-resetting DTCs and often just replaced bad battery modules, so may be different problem). If I do, what would I clean those plugs/terminals with?
    I checked the oil, engine coolant and inverter coolant levels, all are fine. The coolant has never been changed (I have an inverter coolant pump and coolant in the garage, but I haven't made time). Inverter pump seems to be working (I see turbulence in the coolant reservoir).
    Suggestions? I don't have a lot of time to troubleshoot right now because we are getting ready to move (and will be driving this cross-country). But I don't want to take it to a shop and have them throw ECUs and other expensive parts at it if it is a bad connection.
    Thanks!
  2. wjtracy
    wjtracy Senior Member
    11,361
    3,606
    Northern VA (NoVA)
    One thing is inverter coolant pump as they stop working. Also 12v. Also make sure oil is good level.
  3. exstudent
    exstudent Senior Member
    2,214
    905
    Torrance, CA
    P0000 s NOT a valid code. Your Scan Gauge is defective or needs a progrma update. Contact the manufacture.
    If you wish to read ALL codes, it will be best to get Techstream.
  4. JC91006
    16,673
    8,518
    I think you've covered most areas of failure. You checked the radiator level by opening the radiator cap correct?
    It may be time to get a proper code reader or diagnostics from the dealer. The ice not shuting down may just be you having the heater on while you're stopped.
    I don't think your problem is hv battery related, since it should be new
    Raytheeagle likes this.
  5. Jmack111
    Jmack111 Member
    371
    78
    Tacoma wa
    What are the highs and lows of each battery if one off more them 1.2v close to zero the better.
    Sorry old picture
    So look at all the lows and all the highs it will throw a code if it out of balance. But I haven't had those codes but I thought this would be a place to start but I did have random odd codes that didn't make any sense or no codes 90 percent of the time just an error light
  6. Jmack111
    Jmack111 Member
    371
    78
    Tacoma wa
    Do you get water in the 12v compartment or the other side very common with cold weather it could affect the 12 volt battery even more the fix for that is a clear silicone up at the very top of each side of your hatch down to the dust under the check where the roof meets the frame body I always drill a hole to you can drill up the a inch before you hit the battery after the body
  7. wjtracy
    11,361
    3,606
    Northern VA (NoVA)
    One video on Youtube suggests it could be the ECU? unit next to the battery burned out
  8. ericbecky
    ericbecky Hybrid Battery Hero
    4,381
    3,242
    Madison, Wisconsin
    I don't trust your reader.
    Need to double check the diagnostic code.
    For under $60 you can get
    - Android tablet/phone that has WiFi/Bluetooth >$30
    - elm 327 obdii Bluetooth adaptor >$20
    - torque pro app (paid version) >$10
    You need to be able to see the live data about the pack.
    Also can read and clear codes.
    I find the gauge setup jmac111 has too busy for my brain. I choose "Digital dispaly" for the gauges. Much simpler for quick visual diagnosis.
  9. 2manycruisers
    Maryland
    Thanks for all the replies. When I replaced the HV battery, I did check for signs of water entry near the 12V and doesn't appear to happen. I drove it today, warmer and without heat. It seemed to operate normally--the ICE would shut off when stopped or coasting. Electric motor would drive the car at slow speed/slow accel. The battery level still did not change when I was watching-stayed about 3/4 charged, which doesn't seem normal to me. But that could be the change from not running the a/c now that summer is over.
    I need to check the age of the 12V battery again, I don't remember how old it is. I have had the car about 5 years and never replaced it. I did remove the radiator cap to check coolant level. I added oil, too. My experience with the light and oil is the light would briefly flash on a turn when low on oil. I read some suggestions for the battery ECU, but the ones I read were not associated with intermittent or reset-able code. That doesn't mean it isn't the problem, but I'd like to rule out cheaper fixes first.
  10. exstudent
    2,214
    905
    Torrance, CA
    Even at 5yrs old, the battery might still be good. I speculate the previous owner(s) replaced the original 12V at least ONCE, so far. The longest I have heard of an OEM battery being used is 10 YEARS! Even at 10 YEARS, the original 12V AGM battery still had life left, based on the load test performed.
    On the flip side, a different member goes the opposite extreme: prevention. He replaces the 12V battery in all his car's every 4years, no matter what. This is cheap preventative maintenance to replace now, than deal with a need for a jump start due to a dead battery, through no fault of his (ie leaving dome light left on, headlights, etc).
    Post #5) How to apply a load. See how strong the 12V battery is.
    Post #8) State of Charge chart, AGM compatible battery chargers.
    If your car has SKS, it came w/ a 45Amp-Hr battery. Avoid the Optima, b/c it is 38Amp-hr, and pricey. Toyota True Start, Bosch, Exide, AC Delco, have 45Amp-Hr, direct fit replacement 12V AGM battery.
  11. 2manycruisers
    Maryland
    Update, after sitting 2 nights, I checked voltage. On ACC, the mfd showed 11.8v. On IGN-ON, lights on, fan on low, radio on, it showed 10.5v. At the terminals, nothing connected, it shows 12.3v. It is an OEM battery. If I found the right reference to date stamp online, I found printed on the sticker, below and at 90 degrees to the model number is 231010W. This appears to be manufactured October 23, 2010, right? FWIW, this battery has no "true start" label or anything, only GS YUASA.
    I think I will replace the battery and see how it does.
    #11 2manycruisers, Oct 28, 2018
  12. bisco
    51,154
    all correct, time for a new one.(y)
  13. 2manycruisers
    Maryland
    Good deal on a 46 ah battery from NAPA--$148. But it didn't solve the problem. Still have the lights and P0AFA. Sometimes I have 4 lights--the red triangle, a yellow exclamation inside a circle and parens, VSC, and check engine. Sometimes only the red triangle and check engine. Mileage is down, too. MFD shows about 33 mpg average so far. About 9 or 10 lower than it usually shows. Any thoughts?
    I'm preparing for a cross country move and don't have time to spend on this. How do I make sure the mechanic can properly diagnose it and not just swap parts until they find the right one?
  14. exstudent
    2,214
    905
    Torrance, CA
    Stop reading the codes w/ your Scan Gauge; junk IMO, b/c it is NOT able to READ ALL CODES.
    Pay the dealer or a hybrid specialist shop to read the codes. Or get Techstream.
  15. 2manycruisers
    Maryland
    I realize that and is why I said I need to take it to a shop. I was hoping for some helpful advice, maybe from someone who had a similar experience.
  16. bisco
    51,154
    don't trust the new 12v to be charged
  17. 2manycruisers
    Maryland
    Thanks Bisco. If it isn't fully charged when installed, won't the car charge the battery? I waited a while to post in case it went away. It has been in the car for almost 2 weeks now, though I've only put 100 miles on it. The battery has a 10/18 sticker on it, whether that is manufacture or delivery, I am not sure. It was November when I purchased it.
  18. bisco
    51,154
    the car maintains the charge, but does not charge it very well. in fact, it takes about 8 hours of straight driving, or even leaving it on in your driveway, to charge up the 12v. and there is constant drain when the car is off.
    most here use a charger for charging, and a maintainer if they don't drive much
  19. 2manycruisers
    Maryland
    Thanks for the info Bisco!
    Ironically, my car may finally be charged. The light went off this afternoon on its own, and so far has stayed off. I would reset it periodically, but would always come back on. Hard to believe it charges so slowly, but with my experience, I don't think I'll ever bother with maintenance charging.
    Have had the car 5 years and the battery lasted 7. For the last 4, we have been in the city and the car regularly sits for a couple days at a time and sometimes for a week or two. When we do drive it, most often it is for less than 10 miles. If a battery lasted 7 years with that kind of use, this battery will probably outlast my car.
  20. 2manycruisers
    Maryland
    I guess I jumped the gun. The next morning all the lights were back on. I guess it's time to get it to the shop...
