Red triangle and more - need urgent help!
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by cooldyood, Jun 8, 2015.
  1. cooldyood
    cooldyood Junior Member
    45
    Wash DC
    First, some background: On my 2007 Prius, the keyless entry system was steadily failing for the past 2 weeks. The car wouldn't unlock even with key right up to the door. And then it completely stopped working last week, 2 days before I was going for a week-long vacation.
    The car otherwise operated fine with key inserted into the hole below steering wheel.
    I left for vacation last week and left my trunk slightly open (didn't want to come back and struggle with unlocking the car). I returned today, and found something else - the battery was dead.
    A nice guy gave it a jump start, car turned on well but showed on MPD - red triangle + tons of lights + this error "There is a problem with the transmission 'P' lock mechanism".
    After some online digging, I realized this may signal an issue with 12v battery. He jumped 12v battery too, while I ran diagnostics (held display button + turn headlight on/off thrice). Battery showed 11.3v and dropping. However, I could put the car into gear and drive. Red triangle light was still on, all other lights on dashboard were now gone. I drove the car anyway (too tired and lazy to think otherwise).
    After an hour of driving, I ran diagnostics again. Battery now showed 13.9v (screenshot attached) but red triangle light was still on.
    What should I do? Am I ok to drive it 20 miles from work to home? If the logical next step is to take it to a Toyota dealer, can you let me know what to expect..
    #1 cooldyood, Jun 8, 2015
    49,735
    might he have crossed polarity when he jump started you? maybe no harm. what do you mean, he jumped the 12v too? what did he jump the first time? try disconnecting the 12v for a few minutes to see if they go away. i think you can drive the 20 miles. how many miles on her?
  3. cooldyood
    45
    Wash DC
    He definitely did not cross polarities. He and I watched a video and carefully did it together. We jumped both batteries - the one in front and the one in trunk. Just to confirm - 12v is the one in trunk correct?
    My Prius has 168k miles on her.
  4. JC91006
    16,496
    8,406
    There's no battery in the front of the car, it's just a jump point. The battery is located in the back of the car.
    If you charge up/change the 12v battery, all your problems might go away.
  5. andrewclaus
    andrewclaus Active Member
    993
    324
    Golden, CO
    If that's the original 12V battery, it's definitely time to replace it. And be happy you got such good long service out of it.
    The 13.9 V you're reading is during charging, and it should be higher, more like 14.2 to 14.4 as I recall. You're seeing a high voltage drop which means a good battery is charging at a high current, or more likely your battery is bad and will not charge.
  6. Patrick Wong
    18,200
    6,479
    I agree the OP needs to replace the 12V battery now - unless the battery is less than four years old in which case he can try charging the battery overnight with a charger intended for AGM batteries, 4A charging current.
    ~13.8V is the normal voltage produced by the DC/DC converter. If the voltage was 14.4V then the 12V battery would charge faster, but the DC/DC does not produce a voltage that high.
  7. wjtracy
    wjtracy Senior Member
    11,329
    3,593
    Northern VA (NoVA)
    Sounds like you just have a 12v battery issue, I replaced my orig a few years ago on a 2006.
    How many miles on her? Your hybrid battery should be warranted for 8 yrs, maybe 10, I don't think we really know if Toyota handles DC as CARB or not (we must assume not so 8-yrs 100k miles).
  8. cooldyood
    45
    Wash DC
    Update - since the jump start + 1 hour of driving (on day of my original post), almost all problems have disappeared.
    I will certainly prioritize replacing the 12v.
    The only pending issue is key fob failure. If I replace battery on it, is it likely to resolve?
  9. JC91006
    16,496
    8,406
    The key fob battery is an easy and cheap fix
  10. Patrick Wong
    18,200
    6,479
    One hour of driving time is insufficient to charge up the 12V battery, so don't be surprised if you have another no-start incident soon. The battery needs to be charged at least overnight to have a chance of being restored to normal functionality.
  11. cooldyood
    45
    Wash DC
    Second update - key fob restored after changing it's battery last night.
