Red triangle apparently appears for low 12v voltage during drive
Discussion in 'Gen 2 Prius Technical Discussion' started by MNasti, Sep 26, 2017.
  1. MNasti
    MNasti New Member
    Recently while driving the red triangle, vcs and brake warning light came on. Was able to drive home with zero problems. Try to turn on again and would not enter ready mode, only park and neutral with all dash lights on. Disconnected battery for a while and it was able to enter ready mode when reconnected but the red triangle came back while driving. Checked and there were no fault codes but when i checked battery through the diag mode it was at 12.3. Turned on wipers and lights and it went down to 11.7, would not enter ready mode. Went to parts shop and had it charged to 12.5 and it worked normally, but red triangle came back while driving.
    Judging by all the other battery posts its the battery but since the "low voltage scenario" happens while driving when the voltage should be 13.5+, im a little hesitant to spen $200+ on a new battery.
    Is it still possible to have low voltage while the drive batt is supplying power? Can i drive with the diag mode on to monitor voltage?
    49,463
    welcome!
    i suppose if the battery is defective in some way, it is possible. since you need a new battery, why not start there and see what happens? are you gonna ditch the car if it's not the 12v?
  3. fotomoto
    fotomoto Senior Member
    5,602
    3,778
    So. Texas
  4. MNasti
    MNasti New Member
    Thank you for th e help, I will look into that thread.
    For the record though, monitor usually shows battery in the green and only reaches low charge when in slow traffic for mor than 10 minutes. MPG usually shows 45 to 46 as well. Taking it to the dealer to have it checked for $150+ is probably my next step but would add more to the costs if it is just the 12v battery.
  5. TMR-JWAP
    TMR-JWAP Senior Member
    6,225
    5,910
    Columbia, SC
    To add a little fuel to the fire, I ran into something new over the weekend. Car (Gen 2 Prius) has a previously rebuild HV battery, about 2 years old. Symptoms were the red triangle popping up while driving. Owner was resetting by disconnecting battery. Check the codes and the only code present was Block 2 becomes weak. Yet, freeze frame data shows only a 0.3 volt difference from high to low on all modules. Block voltages all looked decent after sitting all night, with about 0.2 volt from high to low. Reset codes and I sat in passenger seat with laptop while going on a test drive. Went through the same thing 2 more times over the next hour. Block 2 every time, but couldn't catch it. Came off the mini-vci and shifted to using android app with battery health check. Did some "hammer down" acceleration testing to get max current draw and max voltage drops. The app showed we actually pulled 150+ amps a few times on acceleration and 90+ on regen. No obvious problems, then driving a steady 65mph on highway, and BANG, triangle pops up. The only thing that made sense to me was a wiring issue.
    We pulled HV battery out, stuck it on the bench and started inspecting. Everything looked decent, even the bus-bars looked good with very minimal corrosion. Then we throw a torque wrench on the terminal nuts. Holy crap..........got anywhere from 1/2 to a full turn on every nut in order to get to 48 inlb torque. SO, we pull the bus-bars off. The back of the bars, only on the negative side, were solid black, like BLACK. Even in the area that was sandwiched between the nut and terminal (which is normally perfectly clean copper). All the threaded terminals and nuts looked fine. Pulled the bus-bars out of the plastic strips and did a quick 15 second muriatic acid dip and swish. They came out looking like new again. We decided to go ahead and take a couple days to cycle the modules and plan to install the pack Thursday evening, with no other changes. So far, all the modules are testing pretty well balanced. Will be interesting to see if the problem goes away.
  6. MNasti
    MNasti New Member
    Thank you for the reply. Note that in my situation, there are no fault codes and the screen doesnt show the battery icon when the red triangle appears. Also, there are no other simptoms that point specifically toward the hv battery that i can recognize.
  7. fotomoto
    5,602
    3,778
    So. Texas
    How was this verified?
  8. MNasti
    MNasti New Member
    Checked on Torque Pro. Diag mode showed all systems ok aswell. If there is another, more legitimate, way to check for faults please let me know.
  9. fotomoto
    5,602
    3,778
    So. Texas
    That should work but it's always been my experience if there is a trouble light there is a trouble code. I use techstream.
  10. jdenenberg
    jdenenberg EE Professor
    3,852
    1,845
    Trumbull, CT
    2020 Prius
    LE AWD-e
    The Toyota diagnostic software contacts ALL of the ECUs, other OBD2 readers only read a subset. I have a MiniVCI that uses an unregistered version of the Toyota SW. You may want to get on eBay and order one.
    JeffD
  11. TMR-JWAP
    6,225
    5,910
    Columbia, SC
    The only lights we received were the red triangle, the brake warning and check engine light. And of course the red car with the exclamation point inside in the upper left corner of the MFD.
  12. edthefox5
    edthefox5 Senior Member
    10,096
    4,806
    Clearwater, Florida
    The red exclamation point is what throws when the 12 volt battery is bad. That's the only fault light you will see that doesn't log a code and it throws when the battery dips below 11.2 I think. Trying to remember when I saw my triangle what the voltage was. Its a courtesy indicator that your 12 volt battery is bad. That indicator does not log a code.
    The red triangle is a master caution light. It will definitely log a code. if your not seeing that code its because your OBDII tester is not hybrid capable. Usually the hybrid battery is bad but will also have a little picture of a car in the upper left of the mfd. The turtle. I say usually becasue we are seeing bad hybrid packs non stop. Its the age of the G2 platform.
    #12 edthefox5, Sep 26, 2017
  13. edthefox5
    10,096
    4,806
    Clearwater, Florida
    Sorry....I meant to say trying to remember when I saw the EXCLAMATION POINT what the voltage was.
  14. ChapmanF
    15,581
    You've rightly noticed that PriusChat is chock full of threads where anybody's warning lights, before any progress has been made diagnosing them, will be answered by three or four people suggesting to focus on the 12 volt battery rather than whatever issue the car's computers are actually reporting. You've also rightly (in my opinion ;) ) questioned that a little.
    As some other posters have pointed out already, you don't get the warning lights without trouble codes, but you sometimes get trouble codes that not every scantool can read (hence the common "I have warning lights but there aren't any codes" posts). I would recommend getting the codes read, and at least for a serious moment considering the possibility that they mean whatever the repair manual says they mean.
    If you get a set of codes that really, honestly, can't be explained after making a diligent effort to understand what the manual says about them, then maybe comes the time to take refuge in "well, I think maybe a battery problem has made all these ECUs crazy". But you won't find me among those who start with that assumption before any serious effort to understand the codes.
    Also, if you get a capable scanner and read the codes and there turn out to be a bunch of them from several different ECUs, that also should not be taken as some kind of sign that the car is crazy. The ECUs talk to each other, and many of them have defined trouble codes that they set only because they have been told of problems by another ECU. When you look up the codes you've read, you'll see which ones those are, and then the large set of codes will not seem so inexplicable.
    In my experience, the most likely result of reading codes from a Prius, looking them up, and honestly working to make sense of them, is finding that the car is telling you exactly what it says it is.
    -Chap
    ILuvMyPriusToo likes this.
