Red triangle, brakes, hybrid warning: after cleaning hybrid fan and going over small bumps
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by wrothgar, Aug 19, 2018.
  1. wrothgar
    wrothgar Junior Member
    77
    16
    oakville, ontario
    I am thinking I have 2 issues here.
    After cleaning the hybrid fan on my gen ii (200 000 km, 2008, second owner....had it for 4 years, 100 000km), the next day the red triangle and brake lights came o on the dash, and the display showed "problem" and a car icon in the top right corner. This occurred immideately after going down hill and hitting a bump (on about a 30 km journey). I wasn't actually driving.
    Dealer found and dixed a corroded wire connection at the battery cooling fan...and claimed the car was fixed.
    Next day, same scenario: about 25 km of driving, bump on a downhill, same lights.
    The front driver wheel bearing had been done twice...I suspect a wheel sensor may be bad, but that's just a guess.
    I have a regular obdii reader...but not a mini vci.
    I have had issues with leaking in the hatch, that seems to be from half way up.
    Dealer says that Toyota's troubleshooting guide points to the "computer under the hybrid battery" being faulty, although they don't think that is the case.
    The second triangle came today, which is a Sunday, so I'm not able to call the dealer back. Normally I don't use the dealer for any maintenance.
    I'm looking for suggestions for how to narrow this down.
    Oil is fine, 12v reads 12.67 V from the batery...inverter pump recall was done a long time ago.
    Both times I wasn't driving, but it sounds like the same conditions that cause the prius to turn on the stability light.
    49,371
    i would start by diving back into the cooling fan, and inspecting every connection, since it is the last thing you touched.
    ITBland likes this.
  3. Paul Schenck
    Paul Schenck Active Member
    522
    306
    Fresno, California
    I would get to the bottom of the leaking situation taking everything out of the back except the battery. Your “small bump”report makes me think of splashing liquid on electronics. Especially after contacts were cleaned. I used to spray WD-40 on my spark plug wires on foggy mornings to start my 68 Cougar. As an electronics lab manager loose and compromised connections make for strange test results. If they recently inspected and cleaned contacts with a contact cleaner they would be even more sensitive to a splash of rusty water from say the battery pan? So I say focus on the leak and you’ll find the cause of this and many other future problems. My own Prius rear door leak was caused by a over enthusiastic cleaning dislodging the weather boot on the hatch electronics umbilical, an easy fix, silicone.
    iPhone ?
    ITBland likes this.
  4. wrothgar
    77
    16
    oakville, ontario
    Thanks. I'll add some photos of the dealer's wire splice. I think it's done poorly.
  5. wrothgar
    77
    16
    oakville, ontario
    I removed the plug at the bottom of the 12 V battery well a long time ago...no water pooling in there. Definitely leaks on passenger rear side of hatch.
    Paul Schenck likes this.
  6. wrothgar
    77
    16
    oakville, ontario
    Here are 3 images showing the dirty connector and broken pin...the quick splice (added yellow wire bridges the brown) and if you look closely, the yellow wire sheathing is completely intact. Is this the way a quick splice is supposed to work? Seems like it isn't right to me.
  7. ITBland
    ITBland Active Member
    433
    272
    New Orleans, La area, US
    No. the quick splice should cut the insulation, but not the wire--looks like the wrong size quick splice was used--Blue is usually for 18-14 AWG wires, those wires don't appear to be that big. If you have to use a quick splice, Red would have been the better choice (typically for 18-22 AWG wires.)
    #7 ITBland, Aug 20, 2018
  8. ITBland
    433
    272
    +1 to this!
  9. Paul Schenck
    522
    306
    Fresno, California
    It does look like that connector has seen some moisture. I’d splice around it with a moisture proof soldered connection?
    iPhone ?
    bisco and ITBland like this.
  10. wrothgar
    77
    16
    oakville, ontario
    Seems to have been the issue. I now need to trace the leaks in the trunk....I think there are a few posts on doing that. Thanks!
  11. bisco
    49,371
    rain gutter seam, hatch hinges.
    Raytheeagle and Paul Schenck like this.
  12. wrothgar
    77
    16
    oakville, ontario
    Is silicone sealant good to use, or is there something better?
    Raytheeagle likes this.
  13. bisco
    49,371
    iirc, that is what most have used.
  14. wrothgar
    77
    16
    oakville, ontario
  15. bisco
    49,371
    silicone
  16. ITBland
    433
    272
    iirc = If I Remember Correctly, not some mythical brand of super sealant :)
    bisco, dolj and Raytheeagle like this.
  17. wrothgar
    77
    16
    oakville, ontario
