Red triangle! Car won't go into 'Ready' Mode
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by FollowJN316, Dec 24, 2019.
  1. FollowJN316
    FollowJN316 New Member
    Illinois
    Hello all! So last week while driving I got the dreaded red triangle warning and when I parked and turned off the car and tried to start it again my dash looked like the picture I attached! I Checked for codes and nothing came up on the code reader! I did lots of research and searching and everyone seemed to say ‘replace the 12v battery’ so I did that and the car started once and I turned it off and tried starting it again... now same issue is happening and won’t go into ‘Ready’ mode... any help would be much appreciated!! When I changed my battery there was some water at the bottom, maybe a half an inch or so, does that mean anything? Thank you all in advance!
  2. ChapmanF
    15,476
    Once you get a code reader capable of reading the codes that are there (or have them read by somebody who has one), the picture will become clearer.
  3. TMR-JWAP
    TMR-JWAP Senior Member
    6,194
    5,891
    Columbia, SC
    That always stinks.
    Apparently your code reader is not adequate for hybrids like the Prius, because codes are there.
    That's because many people instantly jump on the 12v battery as being the problem. Sometimes it is and most times it's not. Never hurts to test it, but hurts about 200 bucks to just go replacing it as a crapshoot solution. Somewhere in your research you may have seen that this is clear evidence that you have a high voltage insolation fault. I would bet that if you disconnect the 12v battery again, it will let you go ready. Once the code comes in again, and you turn off the car, it won't let you restart it again. (unless you disconnect 12v power again)
    You're welcome.
    It means you probably are leaking water into the car from the area around the edge of the hatch seal. There's a few body seams in that area that tend to get small cracks and start leaking.
  4. pasadena_commut
    pasadena_commut Senior Member
    1,454
    440
    Southern California
    It means you have a leak. Fix it before rust becomes a problem. Check the ground from the battery for corrosion.
  5. FollowJN316
    Illinois
    Thank you all so much for your replies and advice/ideas! So small update: I did unhook the negative to my 12v battery and rehooked it and it went to ready mode, when I put it into Drive and waited about 30 seconds the red triangle, circle with the exclamation point and VSC lights came on. I was making my way to Auto Zone to get it read but when I release my gas peddle it makes a strange sound so I turned back around! I’ll go get a reader to get the code but until then anymore thoughts?
  6. TMR-JWAP
    6,194
    5,891
    Columbia, SC
    Yes. The HV isolation fault kicked in again, so it probably won't go ready again until you disconnect the 12v again. Hopefully it's not the transaxle failing, but the only way to know for sure is to get the codes and subcodes .
  7. FollowJN316
    Illinois
    You have been so helpful! Thank you :) I did go to get the codes read but they said nothing is coming up... Is there a certain code reader that I need? My check engine light is NOT on so I'm not sure if that matters or not...
  8. TMR-JWAP
    6,194
    5,891
    Columbia, SC
    Unfortunately, any time you disconnect the 12v battery, it resets all codes. Along with that, even if you have the RTOD on the dash, many code readers aren't hybrid compatible and they won't pick up those codes. If there's a check engine light, which is for the more generic ODB2 codes, they'll read that, but not the hybrid codes.
    You may need to just call a few different auto parts places that do free code scanning to see which one's can check hybrids. Then hope the RTOD pops up while you're driving there.
  9. FollowJN316
    Illinois
    Does this mean anything? I bought a Mini VCI and ran a health check... this is what I got... hopefully I did it right
  10. TMR-JWAP
    6,194
    5,891
    Columbia, SC
    The codes that have a snowflake next to them have freezeframe data. If you click on the snowflake, it will display that data. Post a photo of that data. Many times there is a line item labeled +B or something similar. That's the 12v. What is it showing?
  11. dolj
    dolj Senior Member
    7,631
    3,849
    Wellington, New Zealand
    You have a lot of Uxxxx codes which are various communication problems. You can click on the little blue snowflake icon next to the U0121 and U0124 codes and post up those images.
    I don't think you have said what code readers you tried, but if any of them were Bluetooth dongles, after clicking on the snowflakes, I'd be inclined to clear all codes, do a couple of drive cycles and then scan the car again.
    [EDIT] posted at the same time as TMR-JWAP. LOL.
  12. strawbrad
    953
    999
    Just saw this thread. I thought TMR-JWAP was correct with the isolation fault diagnosis. Then you got all those U codes. I have seen that before. It always led to replacing the Skid Control Computer. It is also know as the ABS Computer.
    That computer is located just above the gas pedal. It's held in with three nuts. The bottom two are not too bad to remove. The top nut is just below the speedometer and is a bear to get to. These computers can be bought cheaply at local junk yards. Use Car-Part.com--Used Auto Parts Market to find one. It is possible to unplug the original computer and plug in the replacement without removing the original. Techstream is needed to initialize the new computer.
    jerrymildred likes this.
  13. FollowJN316
    Illinois
    Okay I have lots of pictures now...
    So the first three are when I hooked it up with all the lights on and me clicking the snowflakes...
    The last ones are after I cleared the codes and let the lights come on after turning the ignition ON...
    I’m worried this is going to cost me a lot to fix
  14. ChapmanF
    15,476
    I would sooner or later troubleshoot the P0AA6 ... that's a real condition, and while one voltage leakage path isn't such a big deal by itself, it's not advisable to let it stay unaddressed long enough for a second one to form and complete a circuit.
    I'm not saying it's related to the other codes; there may be other problems. At the same time, the loss of isolation between the high-voltage system and the body ground could possibly couple electrical noise from the one system into the other and have some influence on comm errors. Not something I've definitely seen, but wouldn't rule it out.
  15. FollowJN316
    Illinois
    I did do the test where you put it in neutral and wait and if the code doesn't appear then put it in drive and wait and they do come on when I go into drive...
  16. strawbrad
    953
    999
    It appears your car has two separate faults happening at the same time. All the U codes point to the ABS computer. They are available for $50 and you can have a replacement in the car in an hour. So that's not a car killing problem.
    For the P0A66 try this test. Be more careful than the guy in video. Wear gloves and use an alligator clip to hold one of the test leads.
    FollowJN316 likes this.
  17. George W
    George W Senior Member
    911
    511
    San Antonio
    I guess I'm not understanding this test. The multimeter in the video had wandering voltage whether his probe or connect to anything or not
  18. strawbrad
    953
    999
    The wandering voltage is only millivolts. Some meters just do that. The point is the reading for a non leaking battery will bleed down to close to zero volts. If the battery has a leak the voltage reading will stabilize.
