Red Triangle + Check engine + ( (!) ) Brake system + Hybrid system on MDF and no code
Discussion in 'Gen 2 Prius Main Forum' started by PANN KETYA, Nov 15, 2018.
  1. PANN KETYA
    PANN KETYA Junior Member
    32
    Camboida
    I have a 2004 prius, while I was driving around 20kmph then on dashboard it show Red Triangle + Check engine + ( (!) ) Brake system + Hybrid system on MDF and Hybrid Fan starting to kick hard that I can clearly hear while listening to music. Also the acceleration is reduced and I pulled over and use my OBD2 Bluetooth to check the code and found P0128 which supposed to be Thermostat. After that I got a thermostat replaced and clean the code then the car driving normally for the last 2 days. Later on it show the same thing ( Red Triangle + Check engine + ( (!) ) Brake system + Hybrid system on MDF ) but this time there is no code found while all those symbols light up.
    What should caused the problem?
    *Note: Airbag lights fixed already.
    Thanks for sharing. 20181111_202531.jpeg 20181111_202536.jpeg 20181111_202549.jpeg
  2. PriusCamper
    PriusCamper Senior Member
    11,119
    4,525
    Pacific Northwest, USA
    There's probably sub-codes that your code reader isn't seeing... the Dr. Prius app for your phone might be of use for that... You have to buy a bluetooth adapter: Hybrid battery diagnostic and repair tool for Toyota and Lexus The other option is the Toyota Techstream reader and computer software. Once you know the error codes this website will tell you how to fix. Also a quick easy fix is to disconnect 12v battery for 5 minutes and let the light and codes clear. They might come back, they might not. Also make sure you have a healthy 12v battery.
    49,567
    welcome!
    you probably need a new hybrid battery
    all the best!(y)
  4. PANN KETYA
    32
    Camboida
    Thanks for the reply.
    I have checked the high voltage battery and they all reading in respectable voltage.
    Thanks
  5. PANN KETYA
    32
    Camboida
    I can clear code thought Bluetooth OBD 2 Scanner and car works fine again. But come up again and again. 12v battery and HV battery also and still the problem. I did a lot of research with this and seems like my inverter pump is bad so I checked it and inside inverter coolant resevior, there's no turbulence or any wave at all then I touched the actual pump but it seems to works fine.
    But why isn't turbulence there?
    Thanks.
  6. bisco
    49,567
    perhaps the pump is humming.vibrating, but not actually pumping
    05PreeUs, Skibob and PANN KETYA like this.
  7. PANN KETYA
    32
    Camboida
    Thanks. I tested, the pump is fine but don't know why there is no turbulence or wave.
    I use LAUNCH scan tool to find codes, and it shows that I have a problem with HV battery in block 6.
    I'm going to replace those two cells and let see if it trips the code again.
    Sorry for my English.
    Thanks for sharing.
    PriusCamper and bisco like this.
  8. bisco
    49,567
    your english is fine, are you going to balance it?
  9. 05PreeUs
    05PreeUs Senior Member
    1,097
    563
    MSP
    Based on photos #1 and #3 in your original post, I'll bet the HV pack has a weak module or two.
    If the HV battery charge meter goes from: top > bottom > top in under say 5 miles of driving, it's in the HV pack.
    Additionally, the HSD cooling pump may be turning, that does NOT mean it is pumping. Debris can get into the system and damage the pump impeller, if that happens eventually the flow stops even if the pump runs.
  10. PANN KETYA
    32
    Camboida
    i don't know how to balance them but i measure all cells include newer and then all giving from 7.4v to 7.8v.
    it seems fine for now. let see if another module fails after it.
    Thanks.
  11. PANN KETYA
    32
    Camboida
    Thanks for your information.
    I got mine fixed by replaced block 6 because of its weakness.
    now car runs fine. let see if other modules will failed after that.
    and i still keep an eyes on Inverter pump also.
    Thanks.
    05PreeUs likes this.
  12. Victorio Mo
    Victorio Mo Member
    110
    29
    Folsom, California
    This is 100% bad Hybrid Battery, (* single or several module).
