Red Triangle, "Check" Icon and "Problem" followed by Red Car Icon on Screen - HELP
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by SparksMemphis, Apr 29, 2010.
  1. SparksMemphis
    SparksMemphis New Member
    Memphis
    I purchased my car used. Shortly after the Maintenance Required light came on but I haven't been able to take care of that yet. Today while driving home I heard a beep followed by the word "Problem" appearing in a bar across the top of the touch screen, an odd shaped icon that im guessing is supposed to resemble an engine(?) above the word "Check" and finally a big red Triangle with an exclamation mark in it. The "Problem" bar disappears after a second and there is a small red car icon in the top left of the touch screen that has a exclamation mark inside it I think.
    I found 4 threads on this forum with similar problems but none of them are exactly like this one. this forums rules wont let me post links until i've made 5 posts which is bs bc the links are the the forum itself.
    one is titled:
    Problem: red triangle & red power light when powering on car
    another:
    red triangle/exclamation point and icon on screen
    another:
    and the last is:
    05 - Check engine light - vapor canister - warranty?
    All seem similar to my situation but they all seem to have different solutions to a very vague problem. I have no idea what these icons mean and it doesnt tell me anything. Is it safe to drive for a while? is it fixing to blow up lol?
    I'm hoping somebody can give me some insight to either what my specific problem is or which one of these existing threads is likely the solution to my issue. i added two photos to hopefully help.
    I found a downloadable "pocket reference guide" at qrg.toyotapartsandservice dot com
    the lights that are coming on in the instrument panel are the "Malfunction Indicator Light" and "Master Warning Light".
    just in case that helps describe my problem
  2. Patrick Wong
    18,209
    6,510
    Does your car demonstrate any unusual issues or symptoms when being driven?
    Do you have access to a digital voltmeter? If so, measure voltage across the 12V battery when the car is IG-OFF and when it is READY.
    The red car with exclamation point in the MFD means that the hybrid vehicle ECU has logged a DTC.
    The amber check engine light means that the engine ECU has logged a DTC.
    The red Master Warning triangle is just alerting you to look around for other warning lights, that may give you a clue as to your car's problem.
    MAINT REQD is driven by an odometer timer, it has been 5K miles since the timer was last reset and you need an engine oil and oil filter change.
    And it looks like your windshield defroster is on.
  3. SparksMemphis
    Memphis
    thanks for the reply!
    theres absolutely no difference in the performance of the car. Drives like it always does. but now theres a giant red triangle reflecting on my windshield hah.
    the 2 warning lights that are on are really generic and dont relate to a specific problem apparently so it's hard to diagnose.
    i dont have a voltmeter :(
    whats a DTC?
    glad the maintenance light isnt that big a deal. i actually had my oil changed since getting the car. do i have to get that done at a dealership for them to reset the light? thats kind of lame it doesnt reset when they're changed bc i've done that since owning it. thanks for the heads up though.
  4. Patrick Wong
    18,209
    6,510
    DTC = diagnostic trouble code
    I suggest that you visit your local Toyota dealer soon because the hybrid vehicle icon in the MFD is a serious warning.
    To reset the MAINT REQD light, set the odometer so that the display shows cumulative miles, not one of the two trip odometers. Make the car IG-OFF.
    Then hold down the button that switches between odometer and the two trip odometers. While holding down the button, depress the POWER button twice (without depressing the brake pedal) so that the car is IG-ON.
    Continue holding the odometer button while you watch a series of dashes appear where the odometer normally is displayed. Once the dashes disappear you can release the odometer button, then make the car IG-OFF.
    SFO likes this.
  5. tokshra
    tokshra New Member
    Indiana USA
    OK, I had this happen to me also...my dealer said I needed an inverter pump and 12 volt battery??? Is this all this means and all the car needs to have done? ..I have always felt safe in this car (2004, 67,000 miles and no other problems).
    What I need to know is will the car be safe to drive after these repairs are made? And also if these are all that should be done?
  6. vertex
    vertex Active Member
    672
    144
    new york
    2018 Prius Prime
    Sparks:
    You may need a 12 volt battery, is yours original? You may also have another problem, like tokshra who needs an inverter pump. You need to read the DTC codes to know for sure. You can test the battery yourself, search on this site for battery test for instructions. If the pump needs to be changed, which is a common failure, then you are good to go for that problem. As the cars age, more problems occur, but the car wehn repaired is perfectly safe to use, assuming there are no other issues.
  7. jdenenberg
    jdenenberg EE Professor
    3,943
    1,940
    Trumbull, CT
    2020 Prius
    LE AWD-e
    You can use "Maintenance Mode" on the MultiFunctional Display (MFD):
    Weird stuff happening? MPGs dropping? Test The Battery | PriusChat
    or go to Radio Shack and buy a low cost Digital Voltmeter for about $40 (a very useful tool).
    JeffD
    The little 12v Battery has a limited life (4-5 years or until it is accidently discharged a few times) so replacing it is normal maintenance.
    The Inverter pump in 2004 and early 2005 Prii has been shown to have early failures. The replacement pump is a newer design and should last a long time.
    At 60k+ miles you should consider having the dealer drain and refill your Automatic Transmission Fluid (Toyota Type WS ATF, ~$100 at my dealer in CT) to extend the life of the Power Split Device (PSD, an expensive item to replace if it fails) which serves as the transmission in a Prius.
    My 2004 Prius is now at 180,000 miles (new Inverter Coolant Pump, original batteries, new ATF 3 times and very few problems) and I expect it to go much further with only normal maintenance and periodic minor problems needing attention (although some minor problems can cost several hundred dollars to repair like the Inverter pump). Just drive your fine car and don't worry too much. Things may break from time to time, but after all it is a car and nothing is perfect.
    JeffD
  8. Rest
    Rest Active Member
    1,210
    CA
    How do you reset this warning light?
  9. jdenenberg
    3,943
    1,940
    Trumbull, CT
    2020 Prius
    LE AWD-e
    You either need an OBD2 tester that handles the CAN Protocol (look into a ScanGuage about $150) or disconnect the 12v battery for a few minutes and reconnect it (usually best done at the negative post connection to the body of the car).
    Of course, if the original problem remains, the warning will return after the reset.
    JeffD
  10. Rest
    Rest Active Member
    1,210
    CA
    I already have a ScanGauge connected to my Prius, but there were no codes showing. The battery had been disconnect for a few hours while I was charging up the battery. But it seems after a few minutes with my Prius running, the warning light went away.
  11. Planet Awesum
    Planet Awesum Junior Member
    26
    32
    Portland, Oregon
    I did this and it worked, after having the red triangle on dash and touch screen . I had just replaced the combination meter.
    "04-09 Prius procedure. Disable SMART KEY (button that says KEY under steering column), and insert key fob transponder into slot in dash. With foot on brake, push power button and hold the power button in for 30 seconds. Release power button and try to restart."
  12. Bryan lasseigne
    Bryan lasseigne New Member
    Baton Rouge
    2008 Prius Master warning light came on and check engine. After reading posts I replaced the 12v battery. Lights came back on. Took to auto zone they said it shows the electric cooling pump is bad. Is this correct?
    Desperate in BR
    #12 Bryan lasseigne, Sep 19, 2019
  13. bisco
    51,930
    welcome!
    depends on what the codes were
  14. bisco
    51,930
    are you going to diy? if so, you should get a prius aware scanner like tech stream
    Kasra likes this.
  15. Bryan lasseigne
    Baton Rouge
    I’ll go again and get code
  16. Patrick Wong
    18,209
    6,510
    Maybe not. You need to retrieve the DTC to have a clue about what is wrong.
    Skibob likes this.
  17. Kasra
    Kasra Member
    48
    27
    Irvine, CA
    Would FIXD be able to read the DTC code?
    FIXD OBD-II Gen II Active Car-Health Monitor - Walmart.com - Walmart.com
    Are there any specific models you would recommend? (Mini VCI not an option here, I don't have a laptop with CD reader not old windows)
    Thanks
  18. Kasra
    Kasra Member
    48
    27
    Irvine, CA
    Any specific model?
    Thanks
  19. bisco
    51,930
    no, they're all the same. tech stream is available on amazon, and runs on your windows laptop
    Kasra likes this.
  20. Kasra
    Kasra Member
    48
    27
    Irvine, CA
    I might give it a shot, I'm replacing both HV inverter pump and battery on the 2008. This is probably the best I can do with these shipping times right now.
    Thanks for your help.
