Red Triangle + exclaimation mark: car won't go into gear
Discussion in 'Generation 1 Prius Discussion' started by [email protected], Feb 28, 2010.
  1. cronin.brendan@gmail.com
    [email protected] New Member
    Oxford
    2002 Prius
    Hello,
    I own a 2002 Prius. Periodically over the last month, the red triangle with the exclaimation mark has been coming on ("Stop driving and take car to a Toyota dealer immediately") and the car going out of gear. Normally I can get it back in gear, but twice I have had to wait about 30 minutes before I can do so. I've taken it to the garage, but they said they cannot identify a problem (the fault light, just resets when they hook up the diagnostics)
    I think it is related to the gear lever ... sometimes I have been lazy and don't push the button fully down on the gear level when I am changing gear. I think this may have something to do with my current problems.
    Anyone have any ideas on how I can fix this ?
    Brendan
  2. Wolfie52
    Wolfie52 Senior "Jr" Member
    143
    124
    No. Carolina
    Unfortunately you have a Generation 1, so you might post in that forum. Good luck.
  3. Tideland Prius
    16,128
    Did you check the 12V battery condition? Just one of many possible root of the problem.
  4. adric22
    adric22 Ev and Hybrid Enthusiast
    642
    144
    Fort Worth, TX
    I wonder if it is possibly an issue with the engine/trans mounts? For example, if the whole assembly is allowed to move too much, perhaps it could cause that?
