Red triangle light on while driving
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by scorpsteals, Jan 18, 2021.
  1. scorpsteals
    scorpsteals New Member
    I have a 2007 Toyota Prius over 130K miles. I received a red triangle light on while driving yesterday along with check engine light on. I checked engine oil and it looked fine. Then I got the codes checked scanned by xpress oil change which returned a bunch of codes:
    P3000: Battery control system
    P3102: Transmission control ECU
    C2300: Actuator System Malfunction
    P0A7F: Hybrid Battery Pack Deterioration
    B1421: Solar Sensor Circuit (passenger Side)
    It does look like the hybrid battery seems to be deteriorating. Could the other codes be related to that or they are different issues. What are my options.
    Thanks.
    Jack Bruce likes this.
  2. SFO
    SFO Senior Member
    5,297
    4,235
    Northern California
    Welcome to PriusChat!!
    You can ignore DTC B1421, if the OBD2 scan was performed in the shade.
    Here is the workup for DTC P0A7F : https://share.qclt.com/%E4%B8%B0%E7%94%B0%E6%99%AE%E7%91%9E%E6%96%AF%E5%8E%9F%E5%8E%82%E8%8B%B1%E6%96%87%E6%89%8B%E5%86%8Cpdf%E6%A0%BC%E5%BC%8F/Repair%20Manual/04pruisr/05/20zmw/cip0a7f.pdf
    Here is the workup for DTC P3000 with the INFs 123, 125, 603 : https://share.qclt.com/%E4%B8%B0%E7%94%B0%E6%99%AE%E7%91%9E%E6%96%AF%E5%8E%9F%E5%8E%82%E8%8B%B1%E6%96%87%E6%89%8B%E5%86%8Cpdf%E6%A0%BC%E5%BC%8F/Prius%20Service%20Manuals%202004/%E4%BF%AE%E7%90%86%E6%89%8B%E5%86%8C/04pruisr/05/21bpm/3000123.pdf
    Here is the workup for DTC P3000 with INF 388 : https://share.qclt.com/%E4%B8%B0%E7%94%B0%E6%99%AE%E7%91%9E%E6%96%AF%E5%8E%9F%E5%8E%82%E8%8B%B1%E6%96%87%E6%89%8B%E5%86%8Cpdf%E6%A0%BC%E5%BC%8F/Prius%20Service%20Manuals%202004/%E4%BF%AE%E7%90%86%E6%89%8B%E5%86%8C/04pruisr/05/21bpm/3000388.pdf
    Here is the workup for DTC P3000 with INF 389 : https://share.qclt.com/%E4%B8%B0%E7%94%B0%E6%99%AE%E7%91%9E%E6%96%AF%E5%8E%9F%E5%8E%82%E8%8B%B1%E6%96%87%E6%89%8B%E5%86%8Cpdf%E6%A0%BC%E5%BC%8F/Prius%20Service%20Manuals%202004/%E4%BF%AE%E7%90%86%E6%89%8B%E5%86%8C/04pruisr/05/21bpm/3000389.pdf
    As you can tell, having the subcode / detail code (aka INF) for the above DTC P3000 might be helpful is tracking down the issue.
    Here is the workup for DTC P3102 (with 7 INFs, DTCs, or subcodes) : https://share.qclt.com/%E4%B8%B0%E7%94%B0%E6%99%AE%E7%91%9E%E6%96%AF%E5%8E%9F%E5%8E%82%E8%8B%B1%E6%96%87%E6%89%8B%E5%86%8Cpdf%E6%A0%BC%E5%BC%8F/Prius%20Service%20Manuals%202004/%E4%BF%AE%E7%90%86%E6%89%8B%E5%86%8C/04pruisr/05/21bpm/3102524.pdf
    Here is the workup for DTC C2300 : https://share.qclt.com/%E4%B8%B0%E7%94%B0%E6%99%AE%E7%91%9E%E6%96%AF%E5%8E%9F%E5%8E%82%E8%8B%B1%E6%96%87%E6%89%8B%E5%86%8Cpdf%E6%A0%BC%E5%BC%8F/Prius%20Service%20Manuals%202004/%E4%BF%AE%E7%90%86%E6%89%8B%E5%86%8C/04pruisr/05/21age/cic2300.pdf
    Do you have a DIY mechanical attitude, or would you be relying on someone else to sort out the above issues for you?
    FYI, you're moderated for five (5) posts.
    JC91006 and Raytheeagle like this.
