Red Triangle Light when Weight in Backseat
Discussion in 'Gen 2 Prius Technical Discussion' started by Ryan Roth, Nov 1, 2019.
  1. Ryan Roth
    Ryan Roth Junior Member
    Nokesville VA
    Have had this issue for a while on my '07 Prius, probably a good 50k-70k miles and have never thought much about it. But since I'm back on here relearning about coolant issues for my '08 figure I'd get some opinions.
    But whenever I have a passenger sit in the back seat, my little red triangle eventually pops up and sporadically goes on and off until I no longer have the passenger. I've gone through tire changes and such over this time so doubt it's tire pressure (if that would even spur the red triangle) if it would maybe it's a faulty sensor?
    I also encounter a temporary red triangle when doing semi long turns when I exit the interstate, which might be related.
    Any idears?
    49,397
    check the oil level
    there is a headlight leveling sensor in the rear suspension that usually corrodes
    in the end, you'll probably have to read the trouble codes
    Ryan Roth and davecook89t like this.
